Hemi twin plug set up,s #219509
02/09/09 09:05 PM
02/09/09 09:05 PM
West Central Wi.
1969 HEMI R-T Online content OP
1969 HEMI R-T  Online Content OP
West Central Wi.
I would like to see some Twin plug Hemi set ups? does any ou here run them. can I see some pics?how complicated are they?
HEMI,S ARE FOREVER!!!
Re: Hemi twin plug set up,s [Re: 1969 HEMI R-T] #219510
02/09/09 09:24 PM
02/09/09 09:24 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
btw, Predator Performance makes dual distributors
about half way down the page
Re: Hemi twin plug set up,s [Re: 1969 HEMI R-T] #219511
02/09/09 09:56 PM
02/09/09 09:56 PM
Springboro, Ohio
Hollywood Offline
Hollywood  Offline
Springboro, Ohio
I run one with an old Pro Stock Accell dual distributor.
Post deleted by Defbob [Re: Hollywood] #219512
02/09/09 10:04 PM
02/09/09 10:04 PM
Re: Hemi twin plug set up,s #219513
02/09/09 10:52 PM
02/09/09 10:52 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Here's one in my buddies '68 Dart. It never really has run that strong though.
Re: Hemi twin plug set up,s [Re: 1969 HEMI R-T] #219514
02/09/09 11:29 PM
02/09/09 11:29 PM
Canada
CrAzYMoPaRGuY Offline
Canada
When I was about to build my engine I searched around for dual plug info and couldn't find much.... most builders were AGAINST the idea in my scenario- a street car.
The engine builder I went with claimed the dual plug setup would COST ME about 30hp....
I love the looks of a dual plug Hemi.
CrAzYMoPaRGuY
Re: Hemi twin plug set up,s [Re: CrAzYMoPaRGuY] #219515
02/09/09 11:45 PM
02/09/09 11:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Wow
I would never thought it would cost that much power, maybe a little for the extra drag on the distributor.
IMO
With today's ignitions, and running normal pump fuel, or even race fuel..I would think it would only be for a visual effect. I would love to see my Hemi one day with a 14-71 Blower, and a Buzzard catcher, and twin plug deal..
I like the old look, I just spent some coinage fixing this old 3700 series Accel tach drive distributor up, to run with a Moroso Monster cable drive tach. I won On Ebay for $38...that's right, the tach, tach bracket, and cable for $38 dollars.. The Petronix Ignitor conversion kit cost me $90 alone. And $60 for the used distributor. I could have had a fancy MSD Pro Billet, but this is way cooler.....
I think its worth it, all to get the look I seek.
Re: Hemi twin plug set up,s [Re: CrAzYMoPaRGuY] #219516
02/09/09 11:48 PM
02/09/09 11:48 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have a set that was max race ported by Koeffel.They are direct connection/dart duel plug heads with ports so huge you can almost fit your fist in!I wonder what they are worth??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi twin plug set up,s [Re: 1969 HEMI R-T] #219517
02/10/09 08:21 AM
02/10/09 08:21 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
here is what the Predator one looks like. It'll give it a sorta "top fuel" look
Re: Hemi twin plug set up,s [Re: Defbob] #219518
02/10/09 09:27 AM
02/10/09 09:27 AM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
My understanding of the dual plug setup is that their is little or no gain in power. But there is a little gain in using the "B" side plug on a single plug head. I do love the look though.
StewartP
Re: Hemi twin plug set up,s [Re: Defbob] #219519
02/10/09 09:46 PM
02/10/09 09:46 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
where is a good site to find a used dual plug distribitor besides e bay?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Hemi twin plug set up,s [Re: toplescuda] #219520
02/10/09 09:56 PM
02/10/09 09:56 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i had an old NOS accel dual distributor a few years ago. wasn't much out there then and really it wasn't anything fancy. well really it wasn't anything (there were no electronics in the housings) if you do like Fred says and look how the 72-73 prostockers were they were all meant to be used with a crank trigger. and seemed the hard part was getting them to fire at the same time
Re: Hemi twin plug set up,s [Re: prochargedhemi] #219521
02/11/09 12:31 AM
02/11/09 12:31 AM
West Central Wi.
West Central Wi.
Thanks for the info. I had herd the second plug location allowed for the engine to be moved back a bit for pro stock if I remember it right. I was after the Looks value. Something like this. only a 8-71 blower. I think a big 10-1471 would make to much heat on a street car. there isn,t much that can mach the looks of a HEMI with this set up,and a Blower/Enderle. IMO
Re: Hemi twin plug set up,s [Re: 1969 HEMI R-T] #219522
02/11/09 04:11 PM
02/11/09 04:11 PM
I do have a 68 Charger which I converted to Twinplug, because it already had the Mopar alu twinplug heads. I took the old Accel cranktrigger type distributor which is empty inside, only the high voltage part there, and I converted the first distributor by adding a spacer and turning down the shaft inside, and adding a standard Mopar RB electronic plate + weights inside, adding a 2. pickup there, so one distributor makes the signals, and both deliver sparks. It works really neat, and gives extreme drivability, and starts really easy. In my manual 3:54 4speed car with stock mech cam, I can run from 10 mph in 4th, and accelerate fast up to top speed (at appx 6000 rpms), or my wife can take it to the grocery no problems.
Re: Hemi twin plug set up,s #219523
02/11/09 04:28 PM
02/11/09 04:28 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Is those 660 center squirter holleys?
Nice setup BTW
Re: Hemi twin plug set up,s [Re: Bob_Coomer] #219524
02/11/09 05:05 PM
02/11/09 05:05 PM
Yes, the carbs are 660 centersquirters. They work very well, but are thirsty. I worked the carbs to make 10% better milage, without sacrifying much. I also made a cam change to the 292 hydraulic with Rhoads lifters, but got some gremlins there, I think my springs are too stiff so there is still some way to go. Next will be a 6-speed ZF transmission (from a Corvette) in a desperate attempt to make it cruise with 318 mileage and have Hemi performance...
Thanks again,
O. Mostad / Norway
Re: Hemi twin plug set up,s [Re: StewartP] #219525
02/11/09 05:09 PM
02/11/09 05:09 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
StewartP
I have heard they worked ok on Nitro cars, just for the added spark though.
Re: Hemi twin plug set up,s [Re: 1969 HEMI R-T] #219526
02/11/09 05:26 PM
02/11/09 05:26 PM
One more thing: If you got a tach drive distributor you can convert it to twin system by taking a 6-cylinder distributor and thread the housing in a lathe to fit the tach system, you can secure it by splitting it and using a clamp over, or just a simple set-screw, then it is simple to grind the shaft to fit the drive. I would recommend th use dual pickups in one master distributor to make it more accurate, and then run the other as a slave. I made such one for a friend of mine. The distributor cap is interchangeable from 6 to 8 cylinder, no problem. This got to be a "poor-man's twin ignition" but it is simple, cost-efficient, compact and it works!! Sorry, did not take pictures of it.
If twin sparks make more hp?: Has to, because timing can be 3 degrees lower (old info from Sox and Martin), this means less counterpressure during firing / full burn. To drive the system costs nothing more than the slight electric and mechanical extra load, maybe a fraction of a hp.
Be aware that the rockers need to be slightly slimmed to fit the 2. tube (very simple job)
Thanks again,
O. Mostad
Re: Hemi twin plug set up,s #219527
02/11/09 06:22 PM
02/11/09 06:22 PM
Springboro, Ohio
Hollywood Offline
Hollywood  Offline
Springboro, Ohio
Here is a picture of my head.
Re: Hemi twin plug set up,s [Re: Hollywood] #219528
02/12/09 06:36 PM
02/12/09 06:36 PM
West Central Wi.
West Central Wi.
Hemi-itis, how old are those heads you have? What's the history on them?
