Hemi twin plug set up,s
#219509
02/09/09 09:05 PM
02/09/09 09:05 PM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
I would like to see some Twin plug Hemi set ups? does any ou here run them. can I see some pics?how complicated are they?
HEMI,S ARE FOREVER!!!
Post deleted by Defbob
[Re: Hollywood]
#219512
02/09/09 10:04 PM
02/09/09 10:04 PM
Re: Hemi twin plug set up,s
[Re: 1969 HEMI R-T]
#219514
02/09/09 11:29 PM
02/09/09 11:29 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
When I was about to build my engine I searched around for dual plug info and couldn't find much.... most builders were AGAINST the idea in my scenario- a street car. The engine builder I went with claimed the dual plug setup would COST ME about 30hp.... I love the looks of a dual plug Hemi.
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#219515
02/09/09 11:45 PM
02/09/09 11:45 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Wow I would never thought it would cost that much power, maybe a little for the extra drag on the distributor. IMO With today's ignitions, and running normal pump fuel, or even race fuel..I would think it would only be for a visual effect. I would love to see my Hemi one day with a 14-71 Blower, and a Buzzard catcher, and twin plug deal..
I like the old look, I just spent some coinage fixing this old 3700 series Accel tach drive distributor up, to run with a Moroso Monster cable drive tach. I won On Ebay for $38...that's right, the tach, tach bracket, and cable for $38 dollars.. The Petronix Ignitor conversion kit cost me $90 alone. And $60 for the used distributor. I could have had a fancy MSD Pro Billet, but this is way cooler..... I think its worth it, all to get the look I seek.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Defbob]
#219519
02/10/09 09:46 PM
02/10/09 09:46 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
where is a good site to find a used dual plug distribitor besides e bay?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: prochargedhemi]
#219521
02/11/09 12:31 AM
02/11/09 12:31 AM
1969 HEMI R-T
West Central Wi.
Thanks for the info. I had herd the second plug location allowed for the engine to be moved back a bit for pro stock if I remember it right. I was after the Looks value. Something like this. only a 8-71 blower. I think a big 10-1471 would make to much heat on a street car. there isn,t much that can mach the looks of a HEMI with this set up,and a Blower/Enderle. IMO
[Re: 1969 HEMI R-T]
#219522
02/11/09 04:11 PM
02/11/09 04:11 PM
I do have a 68 Charger which I converted to Twinplug, because it already had the Mopar alu twinplug heads. I took the old Accel cranktrigger type distributor which is empty inside, only the high voltage part there, and I converted the first distributor by adding a spacer and turning down the shaft inside, and adding a standard Mopar RB electronic plate + weights inside, adding a 2. pickup there, so one distributor makes the signals, and both deliver sparks. It works really neat, and gives extreme drivability, and starts really easy. In my manual 3:54 4speed car with stock mech cam, I can run from 10 mph in 4th, and accelerate fast up to top speed (at appx 6000 rpms), or my wife can take it to the grocery no problems.
#219523
02/11/09 04:28 PM
02/11/09 04:28 PM
Bob_Coomer
Rock Springs
Is those 660 center squirter holleys? Nice setup BTW
[Re: Bob_Coomer]
#219524
02/11/09 05:05 PM
02/11/09 05:05 PM
Yes, the carbs are 660 centersquirters. They work very well, but are thirsty. I worked the carbs to make 10% better milage, without sacrifying much. I also made a cam change to the 292 hydraulic with Rhoads lifters, but got some gremlins there, I think my springs are too stiff so there is still some way to go. Next will be a 6-speed ZF transmission (from a Corvette) in a desperate attempt to make it cruise with 318 mileage and have Hemi performance...
Thanks again, O. Mostad / Norway
[Re: StewartP]
#219525
02/11/09 05:09 PM
02/11/09 05:09 PM
Posts: 4,101 Yes
sixpakdodge
Yes
My understanding of the dual plug setup is that their is little or no gain in power. But there is a little gain in using the "B" side plug on a single plug head. I do love the look though.
StewartP
I have heard they worked ok on Nitro cars, just for the added spark though.
[Re: 1969 HEMI R-T]
#219526
02/11/09 05:26 PM
02/11/09 05:26 PM
One more thing: If you got a tach drive distributor you can convert it to twin system by taking a 6-cylinder distributor and thread the housing in a lathe to fit the tach system, you can secure it by splitting it and using a clamp over, or just a simple set-screw, then it is simple to grind the shaft to fit the drive. I would recommend th use dual pickups in one master distributor to make it more accurate, and then run the other as a slave. I made such one for a friend of mine. The distributor cap is interchangeable from 6 to 8 cylinder, no problem. This got to be a "poor-man's twin ignition" but it is simple, cost-efficient, compact and it works!! Sorry, did not take pictures of it. If twin sparks make more hp?: Has to, because timing can be 3 degrees lower (old info from Sox and Martin), this means less counterpressure during firing / full burn. To drive the system costs nothing more than the slight electric and mechanical extra load, maybe a fraction of a hp. Be aware that the rockers need to be slightly slimmed to fit the 2. tube (very simple job) Thanks again, O. Mostad
