throttle cable with a screw on end at the carb? #2191639
11/07/16 05:56 PM
11/07/16 05:56 PM
IL
furious70 Offline OP
IL
I broke the throttle cable on my 68 Charger. It's got a thread on end rather than the u shaped slip on end at the carb and a ball stud female end threads onto that. Just called mega parts and they've never seen such a thing, anyone know where I can get one? Forgot to take a pic of it this morning.
Also, a part number for the little plastic plug on the pedal assembly that holds the cable in place? That shot off to parts unknown when I was taking it apart...
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2191661
11/07/16 06:27 PM
11/07/16 06:27 PM
AndyF Offline
AndyF  Offline
Doesn't sound like a factory setup, maybe take a picture and post it.
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2191678
11/07/16 07:04 PM
11/07/16 07:04 PM
IL
IL
will do tonight, it looks very OEM, but I've never seen one before.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2191699
11/07/16 07:38 PM
11/07/16 07:38 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Sounds like you have a universal cable repair end.
The plastic plug is P/N 3418847.
http://www.ebay.com/itm/NOS-70-Cuda-71-H...7-/181883889847
You could probably find a hardware store substitute.
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2191705
11/07/16 07:49 PM
11/07/16 07:49 PM
IL
IL
interesting, I've got to look at it closer. the pedal end is all frayed, but maybe I can do a repair on that end if I electrical tape it up like you do before cutting the cable.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2191730
11/07/16 08:28 PM
11/07/16 08:28 PM
IL
IL
O'reily has generic cable ends, I'll probably try to repair the one in the car because the ball stud part is really nice at the carb.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2192027
11/08/16 05:20 AM
11/08/16 05:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not sure how well you can see my cable and the end at the carb but this is a Lokar cable that I use. Does yours look like this ? Ron
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2193018
11/09/16 02:01 PM
11/09/16 02:01 PM
IL
IL
you were right John, the carb end had been repaired. I got a cheap Doorman cable end repair kit, but the cable was unraveled too far. I got an end on it but the cable doesn't smoothly slide into the sheath anymore. A sticky throttle was the original symptom and the cable snapped while I was troubleshooting that.
Ordered a new one from Mancini and will switch the carb back to the other bellcrank style
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: throttle cable with a screw on end at the carb? [Re: furious70] #2195279
11/12/16 05:58 PM
11/12/16 05:58 PM
IL
IL
Is it supposed to keep the plastic over the cable?
70 Sport Fury
68 Charger
69 Coronet
72 RR
