throttle cable with a screw on end at the carb?
#2191639
11/07/16 05:56 PM
11/07/16 05:56 PM
Posts: 2,255 IL
furious70
IL
I broke the throttle cable on my 68 Charger. It's got a thread on end rather than the u shaped slip on end at the carb and a ball stud female end threads onto that. Just called mega parts and they've never seen such a thing, anyone know where I can get one? Forgot to take a pic of it this morning.
Also, a part number for the little plastic plug on the pedal assembly that holds the cable in place? That shot off to parts unknown when I was taking it apart...
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: throttle cable with a screw on end at the carb?
[Re: furious70]
#2191678
11/07/16 07:04 PM
11/07/16 07:04 PM
Posts: 2,255 IL
furious70
IL
will do tonight, it looks very OEM, but I've never seen one before.
[Re: furious70]
#2191705
11/07/16 07:49 PM
11/07/16 07:49 PM
Posts: 2,255 IL
furious70
IL
interesting, I've got to look at it closer. the pedal end is all frayed, but maybe I can do a repair on that end if I electrical tape it up like you do before cutting the cable.
[Re: furious70]
#2191730
11/07/16 08:28 PM
11/07/16 08:28 PM
Posts: 2,255 IL
furious70
IL
O'reily has generic cable ends, I'll probably try to repair the one in the car because the ball stud part is really nice at the carb.
[Re: furious70]
#2193018
11/09/16 02:01 PM
11/09/16 02:01 PM
Posts: 2,255 IL
furious70
IL
you were right John, the carb end had been repaired. I got a cheap Doorman cable end repair kit, but the cable was unraveled too far. I got an end on it but the cable doesn't smoothly slide into the sheath anymore. A sticky throttle was the original symptom and the cable snapped while I was troubleshooting that. Ordered a new one from Mancini and will switch the carb back to the other bellcrank style
[Re: furious70]
#2195279
11/12/16 05:58 PM
11/12/16 05:58 PM
Posts: 2,255 IL
furious70
IL
Is it supposed to keep the plastic over the cable?
