340 .035 Valve Lash What's The Deal #2190698
11/06/16 01:53 PM
11/06/16 01:53 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
I have about .035 valve lash on most of my rockers no preload . Stock rockers the with a flat tapped hydraulic purple shaft cam . No idea which one,Engine already built when I purchased the car. The valves had a ticking noise oil pressure is 45 psi at idle. Checked rockers and notice they were loose. Could it have wrong lifters. I pulled a few bottom looks fine. Check pushrods they are correct length. Anyone every had the problem.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2190825
11/06/16 06:01 PM
11/06/16 06:01 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
AMC lifters?
Angry white pureblood male
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2190842
11/06/16 06:33 PM
11/06/16 06:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Obviously the pushrods are not the correct length for your combo.
Did someone put in an extra fat headgaskets to lower compression?..Since just about everyone lists the same part number for AMC or Mopar lifters I doubt that's it.
Don't be the exception.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2190876
11/06/16 07:37 PM
11/06/16 07:37 PM
OE non adjustable rockers? you have that much lash at the rocker on base circle and the lifter cup is up against the retainer clip? Yes you would need longer pushrods to elim that .035 lash at the rocker & additionally to move the cup below the snap ring (for some preload) and iron adjustable rockers MAY be a solution. EDIT what length of pushrods do you have? MORE EDIT hyd-7.510". hyd with adj rockers-7.23". 273 solid lifter pushrods-7.340"
Re: 340 .035 Valve Lash What's The Deal [Re: RapidRobert] #2191015
11/06/16 10:45 PM
11/06/16 10:45 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It could be the cam was ground on a smaller base circle.
Re-ground cams will have a smaller base.
Same with old aftermarket perf hyd cams, some were ground on a smaller base to get more lift. Often if a hyd cam had more than .510, instructions stated it must be used with adj rockers. New cams are now ground on cores that allow high lifts and still have a std base.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191059
11/06/16 11:31 PM
11/06/16 11:31 PM
You really need to fix that before it causes problems you don't want like a lifter retaining ring coming out and then causing all kinds of other failures work
The motor will make a noticeable amount of more power also getting the valve timing and valve opening corrected up scope
You can have some .060 longer pushrods made that would correct that problem from Manton, Smith Bros or Trend work scope
Re: 340 .035 Valve Lash What's The Deal [Re: Cab_Burge] #2191072
11/06/16 11:43 PM
11/06/16 11:43 PM
What Cab said, it cant be run like this (if we are reading this right: (Hyd lifters with no preload & .035" clearance at the rocker)
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191078
11/06/16 11:48 PM
11/06/16 11:48 PM
P
Porter67 Offline
Porter67  Offline
P
Long ago I tossed a hydro purple cam in a stock 360 and had that same problem, at that time the jinkie mopar adjustable pushrods was a good band aid, alot better options mentioned above to fix your problem.
Id guess the cams probably the 484 or 509, the smaller mopar cams seemed to fit better with oem parts.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191430
11/07/16 02:06 PM
11/07/16 02:06 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
Thanks for all the information I like it when all the options are in a positive manner and all are helpful. At this time the route that I going with is some old 273 adjustable rockers with the correct length hyd pushrods. I had heard about cams being made on smaller base circle but was not sure that the purple shafts were manufactured that way. This engine was built twenty four years ago and never run because when they started it up they didn't have much oil pressure. Then the owner suddenly passed away. SO it set in the garage for twenty four until I bought it. Found the oil gallery plug was missing and replaced it. (Don't ask how I knew to look for that ). Engine runs great other than Alot valve ticking.
Thanks again.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191445
11/07/16 02:21 PM
11/07/16 02:21 PM
Enjoy it while it lasts. (We ain't like this all the time)
Re: 340 .035 Valve Lash What's The Deal [Re: ruderunner] #2191462
11/07/16 02:33 PM
11/07/16 02:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By ruderunner
AMC lifters?
AMC lifters would use shorter pushrods , his are not long enough.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191467
11/07/16 02:37 PM
11/07/16 02:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Was it doing this when you bought it ?
The pushrods are not the correct length if you have that much lash.
Re: 340 .035 Valve Lash What's The Deal [Re: JohnRR] #2191537
11/07/16 03:43 PM
11/07/16 03:43 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
Pushrods measure 7.530 . you are right they are not the right length, but are correct for a stock 340. There is probably enough wear on the old factory rocker combined with a smaller base circle on the cam to get to that lash. Yes it has been this way from the first time I started the engine.
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191574
11/07/16 04:25 PM
11/07/16 04:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sounds like it's not a STOCK 340 so that number goes out the window ... as you can see.
Get a checking pushrod , figure out the length needed , do a few on both banks , and by an ADJUSTABLE length pushrod from Smith Brothers and call it done .
Adjust each pushrod to get the amount of preload you want on every lifter.
Re: 340 .035 Valve Lash What's The Deal [Re: JohnRR] #2191667
11/07/16 06:42 PM
11/07/16 06:42 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
What's wrong with going with a set of 273 adjustable rockers ?
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191723
11/07/16 08:12 PM
11/07/16 08:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nothing, if you have a set .
Re: 340 .035 Valve Lash What's The Deal [Re: ringo440] #2191726
11/07/16 08:24 PM
11/07/16 08:24 PM
Thanks for all the information I like it when all the options are in a positive manner and all are helpful. At this time the route that I going with is some old 273 adjustable rockers with the correct length hyd pushrods. I had heard about cams being made on smaller base circle but was not sure that the purple shafts were manufactured that way. This engine was built twenty four years ago and never run because when they started it up they didn't have much oil pressure. Then the owner suddenly passed away. SO it set in the garage for twenty four until I bought it. Found the oil gallery plug was missing and replaced it. (Don't ask how I knew to look for that ). Engine runs great other than A lot valve ticking.
Thanks again.
Twenty years ago most parts houses and cam grinders stocked the early, pre 1967, and later hydraulic lifters. The early ones, both hydraulics and solid lifters have 1/4 ball cups in them. The 1967 and later Mopar hydraulic lifters use a 5/16 ball size so maybe your motor has mismatch components. They do not have the same height for the pushrod cups in relation to the cam lobes work scope
Mopar, in all of it's infinite wisdom, introduced the LA 318 with hydraulic lifters and stamp steel non adjustable rocker arms in all cars made in the Los Angles plant in 1966, all the other 1966 Cars with 318 motors had the Poly 318 motors with solid lifters shruggy All Mopar V8 shared the same lifters back then, hydraulic or solids, same thing on the 1967 and later Mopar V8 lifters shruggy
Re: 340 .035 Valve Lash What's The Deal [Re: JohnRR] #2191750
11/07/16 08:52 PM
11/07/16 08:52 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
I just so happen to have a set and just ordered 7.23 5/16 ball & cup pushrods from summit
