New best today... Yippee!
#2190306
11/05/16 09:46 PM
11/05/16 09:46 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Good air today(800 foot) had to get out 1 more time. Managed an 11.66 at 114.04. New best by a good bit. That said, this was with the belts off. I plan to make some changes over the winter and swap out the stock fan and water pump , along with the power steering. Just have to find another tenth and a half in worse air to reach my goal with this little 318.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: New best today... Yippee!
[Re: B3422W5]
#2190426
11/06/16 12:10 AM
11/06/16 12:10 AM
Posts: 9,859 MI, usa
dvw
MI, usa
[Re: B3422W5]
#2190430
11/06/16 12:15 AM
11/06/16 12:15 AM
fullmetaljacket
[Re: max_maniac]
#2190431
11/06/16 12:17 AM
11/06/16 12:17 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice. I wanted to try for a new best today to. My mind said yes but my body said no. Unloaded it and put her away till March. Congratulations
[Re: pittsburghracer]
#2190438
11/06/16 12:29 AM
11/06/16 12:29 AM
B3422W5
Portage,michigan
Very nice. I wanted to try for a new best today to. My mind said yes but my body said no. Unloaded it and put her away till March. Congratulations I hear ya. I had to work today. Picked away at getting everything saddled up to run up to 131 after work while it was still open. Once I grabbed the keys to a truck to tow it, everything else was zombie like.... Lol....put one foot in front of the other. Getting old sucks.
[Re: B3422W5]
#2191034
11/06/16 11:12 PM
11/06/16 11:12 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Do you think the MPH jives with that ET? Or is it running out of fuel the last couple of hundred feet from the finish line What are your 1/8 mile and 1000 ft. times and MPH?
[Re: B3422W5]
#2191057
11/06/16 11:31 PM
11/06/16 11:31 PM
B3422W5
Portage,michigan
The slip is in the car at my shop Cab. But I remember the car was 91.99 at half track. 60 foot on that pass was 1.626. That's the best it's ever done there. It does seem kinda mushy when I drop it in high gear. Takes it a while to get to right about 6k as it hits the stripe. Maybe it's just me being used to a much faster car. Has 28 tire and 4.10 gear. Probably would like a 4.30 but not sure if it's worth the trouble
[Re: B3422W5]
#2191279
11/07/16 11:06 AM
11/07/16 11:06 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Very nice! One good running little motor!
[Re: B3422W5]
#2191480
11/07/16 02:47 PM
11/07/16 02:47 PM
Triple Threat
Renton Washington
I bet it would respond to more gear. Shorter tire is the easiest way to experiment with that.
[Re: Triple Threat]
#2191496
11/07/16 03:04 PM
11/07/16 03:04 PM
B3422W5
Portage,michigan
I bet it would respond to more gear. Shorter tire is the easiest way to experiment with that. I have a 275 Hoosier radial on it. Don't know if they make anything shorter, and if they did it would probably look weird on the car.... Lol and for the 400 bucks I could be close money wise to doing the gear swap to a 4.30. The tires on it are shot, got two complete years on them. At the end of the day it's primarily a streetcar, so trying not to lose that part of it to go faster, which is a fine line. I was wondering if the extra gear would help it 60 foot better and get in its power band quicker?
[Re: B3422W5]
#2191508
11/07/16 03:18 PM
11/07/16 03:18 PM
Cab_Burge
As far as making the car 60 ft. better and changing the starting line gear ratio does your tranny have a low ,2.77, low gear set in it now ? If not that may be the better choice to help the car Especially if it is a 904 tranny BTW, I've seen a bunch of different race cars run out of fuel volume the last 300 ft. of the track and not know it If your MPH is down compared to other cars at your track running the same ET maybe you have a unknown problem in the fuel system
[Re: B3422W5]
#2191523
11/07/16 03:26 PM
11/07/16 03:26 PM
B3422W5
Portage,michigan
Here are the incrementals on that pass
1.626 60 foot
330.....4.710 660......7.359...... 91.89mph 1000....9.68..........104.92 1320....11.66.........114.04 Does have a low gear 904.... Or so I was told.
