ifference betwee LA and BB damper? #2189416
11/04/16 01:36 PM
11/04/16 01:36 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
I've got some damers in my garae, how do I tell which belongs to a SB and which to a BB?
Plynouth VIP '67 TT IC EFI
Re: ifference betwee LA and BB damper? [Re: jyrki] #2189467
11/04/16 02:45 PM
11/04/16 02:45 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
BB is painted the dirty small block one is from a 1970 340. The bolts holes are different from cast crank to steel crank.
Re: ifference betwee LA and BB damper? [Re: jyrki] #2189599
11/04/16 07:12 PM
11/04/16 07:12 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 318s were neutral, the 360s all were external balance. The timing marks are different from 273 to 1970 318s, 71-92 318s, 71-93 360s....The 350/383/400/413/426/440 used the same timing markfrom what I recall.
Re: ifference betwee LA and BB damper? [Re: Kern Dog] #2189613
11/04/16 07:52 PM
11/04/16 07:52 PM
I was thinking that the timing marks are the same for '70 up small blocks (on dr side)
Re: ifference betwee LA and BB damper? [Re: jyrki] #2189664
11/04/16 09:25 PM
11/04/16 09:25 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
From what I remember the neck is longer from a small block
Re: ifference betwee LA and BB damper? [Re: R/T1968R/T] #2189671
11/04/16 09:28 PM
11/04/16 09:28 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
x2 on the longer shank thingy
Re: ifference betwee LA and BB damper? [Re: jyrki] #2189874
11/05/16 04:34 AM
11/05/16 04:34 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
So, basically you can machine a BB damper out of a 318 damper? How long is the BB damper overall. I think the ones I have ae 318 dampers nd should get one for a 440 internal balance.
Re: ifference betwee LA and BB damper? [Re: NANKET] #2190199
11/05/16 07:03 PM
11/05/16 07:03 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
It's not a cast/forged thing, it was a year change in '72...all dampers went to a symmetric bolt pattern in '72. Early '72 340 crank was forged, went to cast midyear.
Re: ifference betwee LA and BB damper? [Re: jyrki] #2190249
11/05/16 07:59 PM
11/05/16 07:59 PM
I think all the OEM BB dampeners from 1962 to 1980 have the raised retaining lip on them, all the SB I've seen and early hemi don't shruggy
Re: ifference betwee LA and BB damper? [Re: Cab_Burge] #2190303
11/05/16 09:43 PM
11/05/16 09:43 PM
I set my 318 truck dampener flat on the bench with a straightedge across the snout & it is 1 & 11/32 from under it down to the outer perimeter rim that you stick your timing tape to.
Re: ifference betwee LA and BB damper? [Re: RapidRobert] #2191601
11/07/16 05:02 PM
11/07/16 05:02 PM
Rio Linda, CA
Rio Linda, CA
The same dimension on a BB is 21/32".
