ifference betwee LA and BB damper?
#2189416
11/04/16 01:36 PM
11/04/16 01:36 PM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I've got some damers in my garae, how do I tell which belongs to a SB and which to a BB?
Plynouth VIP '67 TT IC EFI
Re: ifference betwee LA and BB damper?
[Re: Kern Dog]
#2189613
11/04/16 07:52 PM
11/04/16 07:52 PM
RapidRobert
I was thinking that the timing marks are the same for '70 up small blocks (on dr side)
[Re: jyrki]
#2189874
11/05/16 04:34 AM
11/05/16 04:34 AM
jyrki
Finalnd, Perkele
So, basically you can machine a BB damper out of a 318 damper? How long is the BB damper overall. I think the ones I have ae 318 dampers nd should get one for a 440 internal balance.
[Re: NANKET]
#2190199
11/05/16 07:03 PM
11/05/16 07:03 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The bolts holes are different from cast crank to steel crank. It's not a cast/forged thing, it was a year change in '72...all dampers went to a symmetric bolt pattern in '72. Early '72 340 crank was forged, went to cast midyear.
[Re: Cab_Burge]
#2190303
11/05/16 09:43 PM
11/05/16 09:43 PM
RapidRobert
I set my 318 truck dampener flat on the bench with a straightedge across the snout & it is 1 & 11/32 from under it down to the outer perimeter rim that you stick your timing tape to.
[Re: RapidRobert]
#2191601
11/07/16 05:02 PM
11/07/16 05:02 PM
John_Kunkel
Rio Linda, CA
The same dimension on a BB is 21/32".
