Indy 600-13 655 aluminum #2189531
11/04/16 04:44 PM
11/04/16 04:44 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
does anyone know if a 440 camshaft will fit a 600-13 head 655 Indy motor . They look the same to me however ????
Re: Indy 600-13 655 aluminum [Re: robnbird] #2189536
11/04/16 04:51 PM
11/04/16 04:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
What is the valve lay out on those heads compared to the stock wedge heads work Is it E,E,I,I,E,E,I,I,E,E or is it different and like the 426 hemi motors ?
Are the intake ports like the 440 or separate like the Hemiroid motors?
Re: Indy 600-13 655 aluminum [Re: Cab_Burge] #2189552
11/04/16 05:36 PM
11/04/16 05:36 PM
hustlin hoosier Offline
Yes it will fit and if you ever need a back up crank contact me.
Re: Indy 600-13 655 aluminum [Re: robnbird] #2189777
11/04/16 11:33 PM
11/04/16 11:33 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
robnbird..where in tn areyou ? I'm in Jackson..i run 655 also
