Indy 600-13 655 aluminum #2189531
11/04/16 04:44 PM
11/04/16 04:44 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
does anyone know if a 440 camshaft will fit a 600-13 head 655 Indy motor . They look the same to me however ????
Re: Indy 600-13 655 aluminum [Re: robnbird] #2189536
11/04/16 04:51 PM
11/04/16 04:51 PM
What is the valve lay out on those heads compared to the stock wedge heads work Is it E,E,I,I,E,E,I,I,E,E or is it different and like the 426 hemi motors ?
Are the intake ports like the 440 or separate like the Hemiroid motors?
Re: Indy 600-13 655 aluminum [Re: Cab_Burge] #2189552
11/04/16 05:36 PM
11/04/16 05:36 PM
hustlin hoosier Offline
Yes it will fit and if you ever need a back up crank contact me.
Re: Indy 600-13 655 aluminum [Re: robnbird] #2189777
11/04/16 11:33 PM
11/04/16 11:33 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
robnbird..where in tn areyou ? I'm in Jackson..i run 655 also
