Custom made sway bar #2187034
10/31/16 09:52 PM
10/31/16 09:52 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Does anyone have a known good contact for getting a custom sway bar made? It's not for mopar, its for my RX-7 with a 3 rotor in it. I need a bar the same overall specs as stock but with a different bend in the middle of it to clear the oil sump where no oil sump use to be.
I looked at the nascar style splined bars ,but they aren't going to work, I need something with an offset in the middle.
thx
Re: Custom made sway bar [Re: Uberpube] #2187073
10/31/16 10:27 PM
10/31/16 10:27 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Check with a leaf spring shop. If they can not do it, they may have a referral.
Re: Custom made sway bar [Re: Kern Dog] #2187099
10/31/16 11:00 PM
10/31/16 11:00 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Check out this article on The Hot Rod Network If you are handy with fabbing, or have a local Adult Ed school nearby. HTH, Steve
Re: Custom made sway bar [Re: Uberpube] #2187103
10/31/16 11:14 PM
10/31/16 11:14 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Do you not have a local hot rod shop in Alberta that could make one? I could think of 3 places around Winnipeg that could build it if you can't find someone in your area.
A new iron curtain drawn across the 49th parallel
Re: Custom made sway bar [Re: Skeptic] #2187135
10/31/16 11:53 PM
10/31/16 11:53 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
up I have the fab capabilities do all the heating and bending but I couldn't find the metal or hardness specs anywhere to get a start, but there it is , all in that article. Most of the sway bar companies were of no help what so ever.
I'll buy a couple lengths of 4140 tomorrow and get at it, there is a leaf spring shop that does hardening I know of so I'll ask them if they can heat treat it.
Thanks for the replies everyone.
Re: Custom made sway bar [Re: Uberpube] #2187167
11/01/16 01:02 AM
11/01/16 01:02 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Go for it. Those end links are very much like the ones I used back in the mid '70s on the front bar of my '71 Sebring. It worked great. I forget the dia. of the bar.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Custom made sway bar [Re: Uberpube] #2188309
11/02/16 09:02 PM
11/02/16 09:02 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Trying to find 5' of 4140 in 1" is proving to be difficult... Found a place to heat treat it though.
Re: Custom made sway bar [Re: Uberpube] #2188314
11/02/16 09:13 PM
11/02/16 09:13 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
The shop that heat treats it didn't have any recommendations as to where to find some? Usually I don't see it at local metal supply places. You may have to order some from McMaster which may be expensive.
https://www.mcmaster.com/#grade-4140/4142-steel/=14vc6sq
Re: Custom made sway bar [Re: Uberpube] #2188381
11/02/16 10:49 PM
11/02/16 10:49 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
https://www.onlinemetals.com/merchant.cf...amp;top_cat=197
Re: Custom made sway bar [Re: Uberpube] #2188629
11/03/16 11:34 AM
11/03/16 11:34 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
keep us updated, I'm very curious as to how this pans out and the costs associated!
Re: Custom made sway bar [Re: Uberpube] #2188973
11/03/16 08:50 PM
11/03/16 08:50 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
right now that online metals place is probably the best price on the stuff... Every local steel supplier is saying its special order and quoting near 20.00/ft Cdn dollars. My welding table is just big enough to make a jig on for this bar.
Re: Custom made sway bar [Re: Uberpube] #2294262
04/26/17 01:14 AM
04/26/17 01:14 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Spent about 200.00 cdn on materials. Now I have to send it off to be hardened.
Re: Custom made sway bar [Re: Uberpube] #2294410
04/26/17 11:22 AM
04/26/17 11:22 AM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
Why not use a splined torsion bar from Speedway Engineering with bolt on ends? They have a large variety of widths and diameters including tubular. Then you are just modifying the ends to fit.
Re: Custom made sway bar [Re: Uberpube] #2294721
04/26/17 10:48 PM
04/26/17 10:48 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I looked at that option, there was no straight through path for the bar, it had to be offset in the centre as the bar I made is. It's the bulge in the oil pan where the oil pickup tube is for the 20b engine that screws up the path for a straight bar and the fitment of the stock one.
And I got to use fire, which made it kinda fun...
