Custom made sway bar
#2187034
10/31/16 09:52 PM
10/31/16 09:52 PM
Posts: 695 Southern Alberta
Uberpube
Southern Alberta
Does anyone have a known good contact for getting a custom sway bar made? It's not for mopar, its for my RX-7 with a 3 rotor in it. I need a bar the same overall specs as stock but with a different bend in the middle of it to clear the oil sump where no oil sump use to be. I looked at the nascar style splined bars ,but they aren't going to work, I need something with an offset in the middle. thx
Re: Custom made sway bar
[Re: Uberpube]
#2187103
10/31/16 11:14 PM
10/31/16 11:14 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Do you not have a local hot rod shop in Alberta that could make one? I could think of 3 places around Winnipeg that could build it if you can't find someone in your area.
A new iron curtain drawn across the 49th parallel
[Re: Skeptic]
#2187135
10/31/16 11:53 PM
10/31/16 11:53 PM
Uberpube
Southern Alberta
Check out this article on The Hot Rod Network If you are handy with fabbing, or have a local Adult Ed school nearby. HTH, Steve I have the fab capabilities do all the heating and bending but I couldn't find the metal or hardness specs anywhere to get a start, but there it is , all in that article. Most of the sway bar companies were of no help what so ever. I'll buy a couple lengths of 4140 tomorrow and get at it, there is a leaf spring shop that does hardening I know of so I'll ask them if they can heat treat it. Thanks for the replies everyone.
[Re: Uberpube]
#2187167
11/01/16 01:02 AM
11/01/16 01:02 AM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Go for it. Those end links are very much like the ones I used back in the mid '70s on the front bar of my '71 Sebring. It worked great. I forget the dia. of the bar.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Uberpube]
#2188314
11/02/16 09:13 PM
11/02/16 09:13 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Trying to find 5' of 4140 in 1" is proving to be difficult... Found a place to heat treat it though. The shop that heat treats it didn't have any recommendations as to where to find some? Usually I don't see it at local metal supply places. You may have to order some from McMaster which may be expensive. https://www.mcmaster.com/#grade-4140/4142-steel/=14vc6sq
[Re: Uberpube]
#2294721
04/26/17 10:48 PM
04/26/17 10:48 PM
Uberpube
Southern Alberta
I looked at that option, there was no straight through path for the bar, it had to be offset in the centre as the bar I made is. It's the bulge in the oil pan where the oil pickup tube is for the 20b engine that screws up the path for a straight bar and the fitment of the stock one. And I got to use fire, which made it kinda fun...
