Rear Coilover Shock gap #2188954
11/03/16 08:25 PM
11/03/16 08:25 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
So I finished installing the ladder bars and rear shock brackets and went to install the coilovers. The top bolt went in fine but when I went to install the bottom bolt through te coilover there's way too much gap between the coilover and the 2 brackets.
What are you using to fill in the gap?
I don't think you're supposed to use a hardware store washer or 3?
I think there's a specific spacer to put in between the bracket and shock.
Re: Rear Coilover Shock gap [Re: Sammy] #2188987
11/03/16 09:09 PM
11/03/16 09:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
.625" x .058" 4130 tubing (for 1/2" bolts) cut to size, or wide heim in the bottom of the shock or store bought bushings sold by most chassis supply places.
Re: Rear Coilover Shock gap [Re: CMcAllister] #2189281
11/04/16 10:41 AM
11/04/16 10:41 AM
moparx Offline
moparx  Offline
depending upon the application, over the years i have fabbed spacers from aluminum or stainless in varying thicknesses and shapes. a trick to keeping the spacers and shock together while inserting the bolts is to use common sewing thread to tie the spacers to the bearing end[s]. thread is strong and very thin, plus it will usually "disapear" after installation. keeps you from having to grow a third arm and hand. i know it sounds kinda lame, but works for this and other applications your mind can come up with.
beer
Re: Rear Coilover Shock gap [Re: Sammy] #2189603
11/04/16 07:23 PM
11/04/16 07:23 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
http://www.swracecars.com/store/images/cart/thumbs/63074.JPG
There yah go Bud !
S&W Race Cars half moon misalignment bushings
Brett Miller 447 W9
