Thank you Harland Sharp. Excellent service #2188779
11/03/16 03:21 PM
11/03/16 03:21 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
I called and talked to Randy at Harland Sharp on Monday about making me a custom intake rocker for my Edelbrock small block heads. He said they could only modify an Edelbrock rocker around .200-.220 and I wanted to go .350 so he modified (8) W2 style rockers so I could go the full .350 and in the 1.6 ratio I wanted. Now I can totally remove the dogleg pinch and see just how far one of these heads will go. I've already hit 318cfm without moving the pushrods so now am going to push for 330 plus. I was totally surprised when they showed up today. Thanks Randy
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Thank you Harland Sharp. Excellent service [Re: pittsburghracer] #2188781
11/03/16 03:24 PM
11/03/16 03:24 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Awesome. Good luck with it.
Re: Thank you Harland Sharp. Excellent service [Re: pittsburghracer] #2188801
11/03/16 03:47 PM
11/03/16 03:47 PM
GravataĆ­, RS, Brazil
360tripleblack77 Offline
Hi John, Do you have any pictures of your Edelbrock Heads moved .350?
I'm asking because I've Edelbrock Heads ported by myself and I'm interesting in make my "Big Mouth" version...
Thanks,
Diego
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Thank you Harland Sharp. Excellent service [Re: 360tripleblack77] #2188811
11/03/16 03:59 PM
11/03/16 03:59 PM
PA.
"Little"John
"Little"John
PA.
Thanks,
Diego
Not yet. I bought some aluminum rod the I have to install and then redrill the new pushrods holes. My B1 engine is my top priority right now so it may be a month or two
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
