Thank you Harland Sharp. Excellent service
#2188779
11/03/16 03:21 PM
11/03/16 03:21 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I called and talked to Randy at Harland Sharp on Monday about making me a custom intake rocker for my Edelbrock small block heads. He said they could only modify an Edelbrock rocker around .200-.220 and I wanted to go .350 so he modified (8) W2 style rockers so I could go the full .350 and in the 1.6 ratio I wanted. Now I can totally remove the dogleg pinch and see just how far one of these heads will go. I've already hit 318cfm without moving the pushrods so now am going to push for 330 plus. I was totally surprised when they showed up today. Thanks Randy
Re: Thank you Harland Sharp. Excellent service
[Re: pittsburghracer]
#2188801
11/03/16 03:47 PM
11/03/16 03:47 PM
Posts: 192 GravataĆ, RS, Brazil
360tripleblack77
Hi John, Do you have any pictures of your Edelbrock Heads moved .350?
I'm asking because I've Edelbrock Heads ported by myself and I'm interesting in make my "Big Mouth" version...
Thanks,
Diego
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: 360tripleblack77]
#2188811
11/03/16 03:59 PM
11/03/16 03:59 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks,
Diego Not yet. I bought some aluminum rod the I have to install and then redrill the new pushrods holes. My B1 engine is my top priority right now so it may be a month or two
