Re: Flywheel identification??
[Re: GTS440]
#2184035
10/27/16 08:15 PM
10/27/16 08:15 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The basic 130-tooth flywheel didn't change from '62 until the end of production, even the same casting number and they were used on both BB and SB.
External balancing was usually done by drilling a hole or holes of a certain diameter and depth; some external balance drilling is easy to spot but some, like the 340, is so small it can be confused with mass balancing drilling. In that case it helps to know the location of the external balance drilling in reference to the crankshaft bolt hole positions.
Best to post pics of the flywheels in question.
[Re: GTS440]
#2185323
10/29/16 03:13 PM
10/29/16 03:13 PM
John_Kunkel
Rio Linda, CA
#5 and 12 are definitely external balance, diameter and depth of the three large shallow-drilled holes determines which engine.
[Re: GTS440]
#2185824
10/30/16 01:57 PM
10/30/16 01:57 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
Is 21 a mopar flywheel ?
What do the front sides look like? If they have been cut at least once past the factory cut and/or are heat checked, and hard spotted, they might be scrap?
[Re: JohnRR]
#2186034
10/30/16 06:46 PM
10/30/16 06:46 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
What do the front sides look like? If they have been cut at least once past the factory cut and/or are heat checked, and hard spotted, they might be scrap? I had an old Ansen that was back-cut like that wheel with dual paterns Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2186693
10/31/16 02:12 PM
10/31/16 02:12 PM
JohnRR
What do the front sides look like? If they have been cut at least once past the factory cut and/or are heat checked, and hard spotted, they might be scrap? I had an old Ansen that was back-cut like that wheel with dual paterns Gus Reason I asked is because the bolt pattern is not the same as the others. Dan B to the rescue.
[Re: GTS440]
#2191580
11/07/16 04:30 PM
11/07/16 04:30 PM
John_Kunkel
Rio Linda, CA
All cast crank BB's use the same external balance.
