Flywheel identification?? #2183916
10/27/16 05:45 PM
10/27/16 05:45 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
I have a stack of Mopar flywheels & I don't how to distinguish between a flywheel for an internally balanced engine versus an externally balanced engine. I believe flywheels for internally balanced engines are the same between big block & small block of the same diameter but are different on externally balanced engines of the same diameter. So how can I tell which flywheel is for which application? Thanks! GTS
Re: Flywheel identification?? [Re: GTS440] #2184035
10/27/16 08:15 PM
10/27/16 08:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The basic 130-tooth flywheel didn't change from '62 until the end of production, even the same casting number and they were used on both BB and SB.
External balancing was usually done by drilling a hole or holes of a certain diameter and depth; some external balance drilling is easy to spot but some, like the 340, is so small it can be confused with mass balancing drilling. In that case it helps to know the location of the external balance drilling in reference to the crankshaft bolt hole positions.
Best to post pics of the flywheels in question.
Re: Flywheel identification?? [Re: John_Kunkel] #2185207
10/29/16 12:09 PM
10/29/16 12:09 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Here are the pics. All flywheels are indexed with the 2 closest crank holes at the top.
Re: Flywheel identification?? [Re: GTS440] #2185314
10/29/16 03:03 PM
10/29/16 03:03 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
#5 and #12 look like the cast crank versions with the large shallow drillings. The rest look like 'zero' balance pieces.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: Flywheel identification?? [Re: GTS440] #2185323
10/29/16 03:13 PM
10/29/16 03:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
#5 and 12 are definitely external balance, diameter and depth of the three large shallow-drilled holes determines which engine.
Re: Flywheel identification?? [Re: John_Kunkel] #2185739
10/30/16 11:30 AM
10/30/16 11:30 AM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Even #8 with the fly cut & #9 with the 3 extra holes are for internally balanced engines? Thanks! GTS
Re: Flywheel identification?? [Re: GTS440] #2185818
10/30/16 01:46 PM
10/30/16 01:46 PM
W
wayfarer Offline
wayfarer  Offline
W
Keep in mind that cast iron is not as homogenous as a piece of billet and the fly cuts are likely for zero balance.
Re: Flywheel identification?? [Re: GTS440] #2185824
10/30/16 01:57 PM
10/30/16 01:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is 21 a mopar flywheel ?
What do the front sides look like? If they have been cut at least once past the factory cut and/or are heat checked, and hard spotted, they might be scrap?
Re: Flywheel identification?? [Re: JohnRR] #2186034
10/30/16 06:46 PM
10/30/16 06:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had an old Ansen that was back-cut like that wheel with dual paterns shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Flywheel identification?? [Re: fourgearsavoy] #2186553
10/31/16 11:23 AM
10/31/16 11:23 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
#21-Early /6 trucks 11" 172T ring gear for direct drive starter
#17/#2 70-2 440 heavy rod (6pk+HP) 10.5"
#12/#5 360 truck 11"
The rest appear to be neutral balance.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Flywheel identification?? [Re: fourgearsavoy] #2186693
10/31/16 02:12 PM
10/31/16 02:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gus beer
Reason I asked is because the bolt pattern is not the same as the others.
Dan B to the rescue.
Re: Flywheel identification?? [Re: Dan Brewer] #2187015
10/31/16 09:36 PM
10/31/16 09:36 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Thanks all, especially Dan! I was pretty sure one of the flywheels was from my 70 GTX. GTS
Re: Flywheel identification?? [Re: JohnRR] #2187899
11/02/16 09:39 AM
11/02/16 09:39 AM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
#21 does not have the Mopar bolt pattern, I don't know where I got it! GTS
Re: Flywheel identification?? [Re: GTS440] #2191262
11/07/16 10:17 AM
11/07/16 10:17 AM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
I have a 4 speed project coming up & I have a cast crank 440 that I want to use. What does the correct flywheel look like for this application? So I know what to look for? Thanks, GTS
Re: Flywheel identification?? [Re: GTS440] #2191580
11/07/16 04:30 PM
11/07/16 04:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All cast crank BB's use the same external balance.
Re: Flywheel identification?? [Re: John_Kunkel] #2191741
11/07/16 08:44 PM
11/07/16 08:44 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
That's what I needed! Thank you!
