Disc Brake Positioners: necessary? #2187437
11/01/16 03:42 PM
11/01/16 03:42 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I wonder what the function is for the disc brake positioners seen on the 70 and 71 E Bodies with the slider type pin calipers.
I have seen many cars driving around no problem without the positioners or the anti rattle springs....
if you dont run the springs....well you may get some rattle out of the brake pads....
but what about not running the positioners????
Re: Disc Brake Positioners: necessary? [Re: domingo] #2187522
11/01/16 05:44 PM
11/01/16 05:44 PM
can you post a pic of what this part is?
Re: Disc Brake Positioners: necessary? [Re: domingo] #2187535
11/01/16 06:12 PM
11/01/16 06:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Positioners?
Are you talking about the rubber band looking things? If so I never run them.
Don't be the exception.
Re: Disc Brake Positioners: necessary? [Re: Supercuda] #2187597
11/01/16 07:39 PM
11/01/16 07:39 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
These are "positioners"
No, they aren't necessary.
Ma, Mopar did away with them, when they figured out they didn't do any good anyway.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Disc Brake Positioners: necessary? [Re: domingo] #2187599
11/01/16 07:46 PM
11/01/16 07:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ok, he was throwing me off with the "slider type pin calipers"
Re: Disc Brake Positioners: necessary? [Re: domingo] #2187693
11/01/16 10:20 PM
11/01/16 10:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree been running without them for decades.No problems.Rocky
Chrysler Firepower
Re: Disc Brake Positioners: necessary? [Re: Supercuda] #2187976
11/02/16 12:51 PM
11/02/16 12:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes brain fart there....i meant pin style calipers.
Ok guys thanks for the info! Im not gonna worry about having no positioners on the "no need to be factory correct" cars....
Re: Disc Brake Positioners: necessary? [Re: domingo] #2187985
11/02/16 01:01 PM
11/02/16 01:01 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I was crawling under my Challenger convertible recently to see how something was routed for reference for my other Challenger I'm restoring, and noticed on one caliper, the previous owner used the rubber grommets that come with the caliper kits as positioners when he restored the car! The other side had the correct metal ones. I've had the car 19 years and had never noticed that before. At any rate, the brakes have always worked fine in that car, despite not having the correct metal positioners on the one caliper!
