What rear springs for my E body
#2187302
11/01/16 12:07 PM
11/01/16 12:07 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I am looking to replace the stock rear leaf springs on my 71 challenger. My car was originally a plain jane 318 car with 8 3/4 rear end. I have swapped to a 340/727 combo and upgraded to 3.55 limited slip rear. My car sits low in the rear, about an inch of the rear tires (60 series, 15" polyglas) is covered on top by the quarter panels. I had installed air shocks as a quick fix to lift the rear end. When over filled I can raise the rear of the car so I can see about an inch over the tire showing and something close to that would be my final goal for ride height. I now want to do it right so what leaf springs should I get and where is the best place to purchase?? also looking to replace the shocks all the way around. Looking for the best I can get.. Suggestions please....thanks for any help
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
Re: What rear springs for my E body
[Re: fireeng]
#2187323
11/01/16 12:52 PM
11/01/16 12:52 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
ESPO! They make a 1" over stock arch rear spring. I used them on one of my Challengers and loved it. Not overly expensive and excellent service. I use them for all of my cars now. Ditch those air shocks ASAP!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
[Re: fireeng]
#2187425
11/01/16 03:27 PM
11/01/16 03:27 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
http://www.springsnthings.com/Here the link to ESPO springs. Never used them so I have no opinion on how good they are. Have used SS Springs from Chrysler, the older ones lasted with no problems for years and the old springs never relaxed in their height, they were in my A12. Pulled the ladder bars and slider kit out of the Challenger and put a new set of SS springs in the Challenger and they have lost there height very quickly, with in a year. I do not recommend new SS Springs. Using SS Spring you will need the longer front spring hangers. One thing I like that ESPO says in the write up is that the springs are matched in height and that is good for your application being an automatic and small block. There is one other way to go by using the stock springs that would of come on a Hemi or 440-6 car and having those springs redone but you are taking your chances on older springs and the people will set them to the proper ride height.The stock spring numbers end in 024 and 034. The Air shocks, like said above by Erik toss them, buy shocks that are good for your applications and do not alter your spring height and make the springs non effective on acceleration.
[Re: fireeng]
#2187679
11/01/16 10:00 PM
11/01/16 10:00 PM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have fought this battle on a number of occasions and would like to suggest this; order springs with an inch or so MORE lift than you want. Because it is difficult to judge exactly how high the new springs will raise your rear compared to what you have now.
If the new springs are too high, it is easy to use some spacers to get the rear down where you want it. Then there is the chance that the springs will settle at least a little. Then you can pull the spacers and you are back where you want to be.
In other words, too tall is no problem to address. Too low and you're back to the same old issues.
IHTH
Master, again and still
[Re: 1932chrysler]
#2187757
11/01/16 11:32 PM
11/01/16 11:32 PM
fireeng
near New Haven, CT
Thanks Donald!!Good to hear from you, hope all is well.
