Front End Rebuild #2185776
10/30/16 12:59 PM
10/30/16 12:59 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
Going to start working on the 72 Duster the front end totally needs rebuilt is it better to get a whole kit (like from PST) or go to part store and order all the parts I need? What name brand parts are better?
Re: Front End Rebuild [Re: 70dart318] #2185788
10/30/16 01:08 PM
10/30/16 01:08 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I recently did the same on a 65
c body and ordered all Moog from Rock auto for a better price overall. Maybe got lucky but it was all USA made when it came in too. I ordered a second set of several items for the shelf and future repairs.
Re: Front End Rebuild [Re: 65pacecar] #2185800
10/30/16 01:23 PM
10/30/16 01:23 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
iagree Moog and Rockauto are hard to beat. Just be sure to check and make sure that Moog is stamped on all the individual parts.
Master, again and still
Re: Front End Rebuild [Re: 70dart318] #2185862
10/30/16 02:40 PM
10/30/16 02:40 PM
Andrewh Offline
Andrewh  Offline
amazon too, sometimes beats the price. once you have a part number try there.
Re: Front End Rebuild [Re: Andrewh] #2185908
10/30/16 04:01 PM
10/30/16 04:01 PM
I highly recommend Rockauto. good prices/good customer service. More importantly tho I would confirm that EVERY piece you purchase is made in US of A (or similar quality), Australia/new zealand
Re: Front End Rebuild [Re: 70dart318] #2185933
10/30/16 04:36 PM
10/30/16 04:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i used the Energy Suspension 'Hyper-flex' all poly kit in my rebuild last year. while i would recommend the actual pieces and their fit/quality, the 'everything you need' kit had parts that i couldn't use (69 B-body). front stabilizer bar bushings were generic and wouldn't work in the original locations, the lower control arm bushings were impossible to use (so said the machine shop i used to press out the old).
i will take the blame for it though as i ordered it on-line. sadly the days of going to the speed/parts store and actually seeing what you are getting are over unless you are a chebby or ford guy.
Re: Front End Rebuild [Re: mikemee1331] #2186174
10/30/16 09:47 PM
10/30/16 09:47 PM
IN
ahy Offline
ahy  Offline
IN
Part quality in some of the kits has been variable.
I would suggest Moog/Rock Auto or a kit from Firm Feel.
Re: Front End Rebuild [Re: 70dart318] #2186202
10/30/16 10:16 PM
10/30/16 10:16 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Although I've not used it, the kit from Bill Rolik Enterprises has always peaked my interest. I'm about to the point where I'm going to start buying parts for a complete restoration and suspension has been one of the areas I've looked around for good parts.
Re: Front End Rebuild [Re: 70dart318] #2186519
10/31/16 10:28 AM
10/31/16 10:28 AM
Streetsboro,Ohio
Streetsboro,Ohio
Thank You for your help
