360-1 Indy heads...Where to buy? #2185014
10/29/16 12:00 AM
10/29/16 12:00 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I've narrowed it down to the small block Indy cylinder heads. I've been out of the game for a while where is the best place to buy them from?
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185104
10/29/16 02:48 AM
10/29/16 02:48 AM
SoCal
Brian Hafliger Offline
SoCal
We sell all Indy products, as well as touching up their finish work.
I also pressure test the heads before we send them out...
Brian
Brian Hafliger
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185156
10/29/16 09:32 AM
10/29/16 09:32 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Did you look at the victor heads
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185194
10/29/16 11:19 AM
10/29/16 11:19 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I did but they are $4000!! Not worth that to me and at the end of the day the Indy will suit me fine.
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185230
10/29/16 12:38 PM
10/29/16 12:38 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Trust me you can go fast with the indy stuff. Get the 245 CNC heads!
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185236
10/29/16 12:53 PM
10/29/16 12:53 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Unless it's going to be an all out max effort deal, I would buy the Bloomer Engineering 225 heads. Cheaper than Indy, better CNC work and valve job is already professionally done.
They are good enough to get anything in the 9's without working up a sweat.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 360-1 Indy heads...Where to buy? [Re: Brian Hafliger] #2185361
10/29/16 04:05 PM
10/29/16 04:05 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Brian
Brian is a good dude ! Mine are still working well
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185405
10/29/16 06:00 PM
10/29/16 06:00 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
there is a sb duster here at Mir with the 360-1 heads, running 8.95 on the motor...I'd say it's a good head
Re: 360-1 Indy heads...Where to buy? [Re: DaKuda] #2185710
10/30/16 10:28 AM
10/30/16 10:28 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Trust me Indy is a good head I would not lie lol
