Re: 360-1 Indy heads...Where to buy?
[Re: DaKuda]
#2185104
10/29/16 02:48 AM
10/29/16 02:48 AM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
I've narrowed it down to the small block Indy cylinder heads. I've been out of the game for a while where is the best place to buy them from? We sell all Indy products, as well as touching up their finish work. I also pressure test the heads before we send them out... Brian
Brian Hafliger
[Re: DaKuda]
#2185236
10/29/16 12:53 PM
10/29/16 12:53 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Unless it's going to be an all out max effort deal, I would buy the Bloomer Engineering 225 heads. Cheaper than Indy, better CNC work and valve job is already professionally done. They are good enough to get anything in the 9's without working up a sweat.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Brian Hafliger]
#2185361
10/29/16 04:05 PM
10/29/16 04:05 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
I've narrowed it down to the small block Indy cylinder heads. I've been out of the game for a while where is the best place to buy them from? We sell all Indy products, as well as touching up their finish work. I also pressure test the heads before we send them out... Brian Brian is a good dude ! Mine are still working well
