Show me your 6 pack setups please, stock to whatever #218500
02/09/09 08:46 AM
02/09/09 08:46 AM
an8sec70cuda Offline OP
I'd like to see pics of some different big block six pack setups, INCLUDING factory stock setups. What do you have? CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Show me your 6 pack setups please, stock to whatever [Re: an8sec70cuda] #218501
02/09/09 09:48 AM
02/09/09 09:48 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
6-pak in my 65 coronet.
Re: Show me your 6 pack setups please, stock to whatever [Re: lewtot184] #218502
02/09/09 09:53 AM
02/09/09 09:53 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Show me your 6 pack setups please, stock to whatever [Re: sixpackgut] #218503
02/09/09 01:19 PM
02/09/09 01:19 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
How well does that nitrous work on your sixpack? I just put the NOS plate setup on my 340 six barrel and can't wait to see how well it works. What hp do you have it jetted for?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Show me your 6 pack setups please, stock to whatever [Re: lewtot184] #218504
02/09/09 01:29 PM
02/09/09 01:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
LEW, how's that one-piece kickdown work??? I was thinking of using one on my 70 440-6 Charger.. Stock 6 pack set-up here, engine "a little warmed up"
Re: Show me your 6 pack setups please, stock to whatever [Re: 11secaarcuda] #218505
02/09/09 01:55 PM
02/09/09 01:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
havnt tried it yet
Re: Show me your 6 pack setups please, stock to whatever [Re: Mr.Yuck] #218506
02/09/09 02:16 PM
02/09/09 02:16 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i fabbed up the kick-down stuff. it works great. i'm using the original cable tranny and there isn't any provision (mounting bosses) on the housing to use regular 6-pak kickdown linkage. also, i don't think a one piece will work on the 66-70 b-bodies because the engine sits about 1 1/2" closer to the firewal. the one piece rod would probably hit the firewall at WOT. if you can't find the correct parts its fairly easy to modify four barrel stuff to work.
Re: Show me your 6 pack setups please, stock to whatever [Re: lewtot184] #218507
02/09/09 02:33 PM
02/09/09 02:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I recall Using one on a 69 Charger. It was a 440 4bbl I yanked form a 71 Fury. I used the one piece but I recall having to tweak it some. I can get the factory 4bbl kickdown. I just thought the one piece might be easier to adjust.
Re: Show me your 6 pack setups please, stock to whatever [Re: Mr.Yuck] #218508
02/09/09 03:05 PM
02/09/09 03:05 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Here's mine.
4 speed car.
Re: Show me your 6 pack setups please, stock to whatever [Re: Mr.Yuck] #218509
02/09/09 03:37 PM
02/09/09 03:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the way mine is set up adjustment is the same as any early or later b-body.
Re: Show me your 6 pack setups please, stock to whatever [Re: an8sec70cuda] #218510
02/09/09 04:49 PM
02/09/09 04:49 PM
San Diego CA
Bruce K Bridges Offline
San Diego CA
Heres my EFI 440 6bbl in my 74 Interceptor
Lokar kick down cable on the central TB...
Re: Show me your 6 pack setups please, stock to whatever [Re: Bruce K Bridges] #218511
02/09/09 05:23 PM
02/09/09 05:23 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Cool six pack EFI
OK, I give up, what's a 74 Interceptor?
Re: Show me your 6 pack setups please, stock to whatever [Re: Bigcube] #218512
02/09/09 05:47 PM
02/09/09 05:47 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Cool six pack EFI
UHH!, As in Jensen/Healy Interceptor. Basically a British sports car with various Mopar motors (including 440's) stuffed into them. Not many around even when new and fewer now. I think they stopped making them around 74-76.
