Show me your 6 pack setups please, stock to whatever
#218500
02/09/09 08:46 AM
02/09/09 08:46 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I'd like to see pics of some different big block six pack setups, INCLUDING factory stock setups. What do you have? CHIP
Re: Show me your 6 pack setups please, stock to whatever
[Re: an8sec70cuda]
#218501
02/09/09 09:48 AM
02/09/09 09:48 AM
Posts: 3,916 usa
lewtot184
usa
[Re: sixpackgut]
#218503
02/09/09 01:19 PM
02/09/09 01:19 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
How well does that nitrous work on your sixpack? I just put the NOS plate setup on my 340 six barrel and can't wait to see how well it works. What hp do you have it jetted for?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: Mr.Yuck]
#218506
02/09/09 02:16 PM
02/09/09 02:16 PM
Posts: 3,916 usa
lewtot184
usa
LEW, how's that one-piece kickdown work??? I was thinking of using one on my 70 440-6 Charger.. Stock 6 pack set-up here, engine "a little warmed up"
i fabbed up the kick-down stuff. it works great. i'm using the original cable tranny and there isn't any provision (mounting bosses) on the housing to use regular 6-pak kickdown linkage. also, i don't think a one piece will work on the 66-70 b-bodies because the engine sits about 1 1/2" closer to the firewal. the one piece rod would probably hit the firewall at WOT. if you can't find the correct parts its fairly easy to modify four barrel stuff to work.
[Re: lewtot184]
#218507
02/09/09 02:33 PM
02/09/09 02:33 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I recall Using one on a 69 Charger. It was a 440 4bbl I yanked form a 71 Fury. I used the one piece but I recall having to tweak it some. I can get the factory 4bbl kickdown. I just thought the one piece might be easier to adjust.
[Re: Mr.Yuck]
#218509
02/09/09 03:37 PM
02/09/09 03:37 PM
Posts: 3,916 usa
lewtot184
usa
the way mine is set up adjustment is the same as any early or later b-body.
[Re: an8sec70cuda]
#218510
02/09/09 04:49 PM
02/09/09 04:49 PM
Posts: 37 San Diego CA
Bruce K Bridges
San Diego CA
Heres my EFI 440 6bbl in my 74 Interceptor
Lokar kick down cable on the central TB...
[Re: Bigcube]
#218512
02/09/09 05:47 PM
02/09/09 05:47 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
Cool six pack EFI
OK, I give up, what's a 74 Interceptor?
UHH!, As in Jensen/Healy Interceptor. Basically a British sports car with various Mopar motors (including 440's) stuffed into them. Not many around even when new and fewer now. I think they stopped making them around 74-76.
