Re: new gas sending unit ohms numbers
[Re: moparpro]
#2182179
10/25/16 02:34 PM
10/25/16 02:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
2 ohms difference won't be an issue. If it read 100 then you'd be in trouble.
[Re: moparpro]
#2182272
10/25/16 04:23 PM
10/25/16 04:23 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
How good is your VOM meter? Will it zero on ohms? If not add your zero error into the readings I thought all Mopar had 30 to 90 ohm fuel sending units I'll dig out one of my FSM and read that part over again on trouble shooting the fuel gauge circuit.
[Re: moparpro]
#2182502
10/25/16 09:03 PM
10/25/16 09:03 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
when i installed my new one i had 75 and 13. i was and still is 1/4 of a tank off no matter how much f'ing around i did.
as Supercuda stated, 2 ohms makes no difference...
FYI- i got mine from Dixie Restoration and it's made in Mexico. we all had high hopes for these ones.
[Re: moparpro]
#2182741
10/26/16 01:38 AM
10/26/16 01:38 AM
Posts: 1,822 Colorado
denfireguy
Colorado
My experience is 8-10 ohms full, 80 ohms empty on original equipment. Very non linear as well due to the shape of the tank. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Nukechargerboy]
#2183033
10/26/16 03:32 PM
10/26/16 03:32 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
What brand of meter? Fluke meters have a range button. If you take it out of auto range you can change the values to get rid of the 'bounce' that could be the prob it doesnt have a range setting,just a ohm symbol.i put my old unit back in and it reads perfect on the gas gauge but i need the 1/2 inch unit for my combo.
[Re: moparpro]
#2183258
10/26/16 09:21 PM
10/26/16 09:21 PM
Posts: 5,883 ohio
ruderunner
ohio
At be just me but I've found that you YOU cannot be touching the probes or wiring when checking this stuff. The better meters will actually read the resistance of your body! And yes the human body does have resistance and the ability to conduct electricity.
Few years back I was feeling some stray voltage in the wiring to one of my lifts. Couldn't measure it on a meter but it was there. Took a few days to figure out it only happened when I was touching the lift and the compressor was running found a wire in the compressor just barely touching ground.
Angry white pureblood male
[Re: ruderunner]
#2183480
10/27/16 12:32 AM
10/27/16 12:32 AM
Cab_Burge
One of the first test we had to do in basic direct current electricity class in college was to zero the VOM meter and measure our bodies resistance, I learned early the harder I pinch the probes the less resistance my body had I think they where teaching back then that our bodies are 80% liquid, women have less body resistance than men also I'm trying to remember which Rock and Roll singer died when the cord to his microphone got worn and shorted out inside, he touch the mike to his lips and died from being electrocuted on the stage
[Re: moparpro]
#2183597
10/27/16 08:57 AM
10/27/16 08:57 AM
Supercuda
About to go away
About to go away
up yours
clue CB, you don't zero DMM and only a seriously old fart still has a VOM.
[Re: bonefish]
#2183852
10/27/16 04:01 PM
10/27/16 04:01 PM
dogdays
Lay off of Cab, your ignorance is showing. A digital Multimeter IS a VOM. See quote below:
"A multimeter or a multitester, also known as a VOM (Volt-Ohm meter or Volt-Ohm-milliammeter), is an electronic measuring instrument that combines several measurement functions in one unit."
Straight from the internet bible of knowledge, Wikipedia.
There are some things where the analog indicator is better than digits. That's why Fluke, several years ago, added a bar graph that works in analog fashion.
As for me, I have a Fluke, the cheap Radio Shack pocket meter, the Freebee from Harbor Freight, and two GBs purchased from Walmart. Oh, and on my bench I have a pristine Simpson 260.
You can never have too many tools.
R.
[Re: bonefish]
#2183902
10/27/16 05:21 PM
10/27/16 05:21 PM
mikemee1331
bethlehem pa
I went thru 3 bad sending units. They are junk. I bought one from Kramers auto and it reads perfect. http://www.kramerauto.com Went to their web site all they had was sheet metal it's in the catalog. $125 for 1/2 or 3/8 if i remember.
[Re: dogdays]
#2183947
10/27/16 06:15 PM
10/27/16 06:15 PM
Supercuda
About to go away
About to go away
up yours
Straight from the internet bible of knowledge, Wikipedia. Same source, your internet bible called Wikipedia says "Digital multimeters (DMM, DVOM) have a numeric display, and may also show a graphical bar representing the measured value. VOM is analog, DVOM or DMM is digital. Reading comprehension is key. As for the Simpson 260, they were crap new, I used to have to repair and calibrate them and they were a giant bakelite encased POS. Thank god for Fluke and the DMM.
