Can 6.1L heads be modified/swapped side to side? #2180896
10/23/16 04:27 PM
10/23/16 04:27 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I've got a damaged drivers side 6.1L cylinder head. The power steering pump was hit from the side and it ripped the PS pump mounting bolts out of the head and broke off pieces of the mounting pad. I know the heads are side specific and have separate part numbers but it looks to me like I could swap heads from side to side and just drill/tap new mounting bolt holes for the PS pump. Other then those mounting holes they look identical. Thoughts?
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2181035
10/23/16 09:09 PM
10/23/16 09:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You will have to re-drill the exhaust bolt pattern as well.
Mopar to the bone!!!
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2181067
10/23/16 09:50 PM
10/23/16 09:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have seen a guy tap the heads so he could flip the manifolds forward for a turbo application, didn't look like a horrible ordeal.
68 Barracuda Formula S 340
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2181115
10/23/16 11:00 PM
10/23/16 11:00 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
What about oil drainback holes??
Re: Can 6.1L heads be modified/swapped side to side? [Re: sixpackgut] #2181180
10/24/16 12:37 AM
10/24/16 12:37 AM
IN
ahy Offline
ahy  Offline
IN
Sounds like it may be easier/better to weld up and re-machine the damaged area.
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2181190
10/24/16 12:55 AM
10/24/16 12:55 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
look , i dont think you can.. thats why there are 2 different head gaskets, if you could then both HG would be the same.. think about it!
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2183065
10/26/16 04:16 PM
10/26/16 04:16 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I used two left side heads on my 5.7. Had to use two left head gaskets and block on of the oil drain back passages. I didn't have to re-drill the exhaust holes.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2183161
10/26/16 06:35 PM
10/26/16 06:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Dave weber does them.
Re: Can 6.1L heads be modified/swapped side to side? [Re: 70B5Cuda] #2183432
10/26/16 11:43 PM
10/26/16 11:43 PM
Canada
onig Offline
onig  Offline
Canada
Apache heads. Left and Right
Notice the oil drain back hole in the top pic.
69 Dart
