Can 6.1L heads be modified/swapped side to side?
#2180896
10/23/16 04:27 PM
10/23/16 04:27 PM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
I've got a damaged drivers side 6.1L cylinder head. The power steering pump was hit from the side and it ripped the PS pump mounting bolts out of the head and broke off pieces of the mounting pad. I know the heads are side specific and have separate part numbers but it looks to me like I could swap heads from side to side and just drill/tap new mounting bolt holes for the PS pump. Other then those mounting holes they look identical. Thoughts?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: Can 6.1L heads be modified/swapped side to side?
[Re: 70B5Cuda]
#2181035
10/23/16 09:09 PM
10/23/16 09:09 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You will have to re-drill the exhaust bolt pattern as well.
Mopar to the bone!!!
[Re: 70B5Cuda]
#2181067
10/23/16 09:50 PM
10/23/16 09:50 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I have seen a guy tap the heads so he could flip the manifolds forward for a turbo application, didn't look like a horrible ordeal.
68 Barracuda Formula S 340
[Re: 70B5Cuda]
#2181115
10/23/16 11:00 PM
10/23/16 11:00 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What about oil drainback holes??
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 70B5Cuda]
#2183065
10/26/16 04:16 PM
10/26/16 04:16 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
I used two left side heads on my 5.7. Had to use two left head gaskets and block on of the oil drain back passages. I didn't have to re-drill the exhaust holes.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
