indy roller rockers F body K frame #2180737
10/23/16 09:59 AM
10/23/16 09:59 AM
new york
Bill Gardner Offline OP
new york
Ok guys I know there is a lot of knowledge out there and I need info on a couple things. I need new rollers for my black indy -1 rockers.who makes the rockers and where can I get a set of 16 replacements? indy wont sell them just a replacement rocker.
next does any one make a tube K frame for an F body aspen if not I am open to all ideas. thanks
Re: indy roller rockers F body K frame [Re: Bill Gardner] #2180751
10/23/16 10:50 AM
10/23/16 10:50 AM
IN
ahy Offline
ahy  Offline
IN
On the tube K frame, what are the objectives? Header and pan clearance for a drag car or better handling?
On the rockers, I would wonder about things like pin retention after changing rollers. Would they hold? Are the rockers already fatigued? Maybe some have had good luck changing rollers but I wouldn't want to try it personally.
Re: indy roller rockers F body K frame [Re: ahy] #2180784
10/23/16 12:16 PM
10/23/16 12:16 PM
new york
new york
yes it is for a drag car.oil pan and external oil line clearance is one objective but mostly weight.that k frame weighs a ton.
as far as the rockers they are new never mounted spares on shafts that were left in a storage container that some how was left open and got water in it rusting some of the rollers.
Re: indy roller rockers F body K frame [Re: Bill Gardner] #2180785
10/23/16 12:23 PM
10/23/16 12:23 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
How many Indy rockers do you need? I bought a used -1 top end kit and never used the rockers. I believe 12 of the 16 are good. I would have to look again.
Re: indy roller rockers F body K frame [Re: Bill Gardner] #2180789
10/23/16 12:32 PM
10/23/16 12:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Might want to peek at this thread for ideas.
https://board.moparts.org/ubbthreads/ubbt...ng-at-home.html
Don't be the exception.
Re: indy roller rockers F body K frame [Re: Charger453] #2180880
10/23/16 03:37 PM
10/23/16 03:37 PM
new york
new york
thanks guys. Iam trying to find the roller bearing in the end of the rocker that contacts the valve,thought it would be an easy swap and available with the pin/shaft it rides on. does that pin/shaft press out or screw in? anyone know who actually makes these rockers for indy?if so I would contact them and have them do it. the rockers and shafts are new just rusty rollers.
guess the tube K frame is like hens teeth. had a suggestion for a fox body mustang k frame and pinto. pinto is too narrow,have one here. anyone know of something in a kit form I can weld up? thanks for your help.
Re: indy roller rockers F body K frame [Re: Bill Gardner] #2180892
10/23/16 04:15 PM
10/23/16 04:15 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Dove makes the rockers, I believe.
Re: indy roller rockers F body K frame [Re: Bill Gardner] #2181023
10/23/16 08:56 PM
10/23/16 08:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
RMS use to sell complete systems for the f body if the was what you were asking. https://www.reillymotorsports.com/store/home.php
Re: indy roller rockers F body K frame [Re: Bill Gardner] #2182250
10/25/16 04:00 PM
10/25/16 04:00 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Re: indy roller rockers F body K frame [Re: Charger453] #2182266
10/25/16 04:19 PM
10/25/16 04:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree scope
More than likely there is a axle and shaft, no needle bearings in the roller tip or on the shafts scope Those are extruded aluminum rockers with no caged needle bearing in the main body, correct? If so step up now and buy either a set of Harland Sharp roller rocker arm kit with 1.6 ratio or a set of the T&D single shaft 1.6 ratio rockers for your heads twocents up
