Re: Dual EGT Thermocouple Placement
[Re: Cuda_Mike]
#2178988
10/20/16 04:18 AM
10/20/16 04:18 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I put bungs in every pipe so I could have 2,,4,,,,or 8 egts.
But I have none,just o/2s
[Re: Cuda_Mike]
#2179000
10/20/16 07:48 AM
10/20/16 07:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I was thinking the two most rear ones would be the hottest because they are the farthest from any form of cooling. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2179006
10/20/16 08:49 AM
10/20/16 08:49 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I was thinking the two most rear ones would be the hottest because they are the farthest from any form of cooling. Tim Cooling system temps have little impact on EGT. EGT will be all about air/fuel distribution of the intake manifold runners. No cheap/easy way to determine where to place them unless the weakness of a particular intake is well known and documented. You could use a heat gun on suspected cylinder header tube but you would have to be doing pulls on a dyno while trying to take a reading which could be problematic.
"I think its got a hemi"
[Re: Cuda_Mike]
#2179054
10/20/16 11:30 AM
10/20/16 11:30 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I would love to datalog 8 EGTs but I wasn't in that mind set when I got my headers coated. It would be very handy to balance the cylinders since I have EFI. I guess eventually the shiny headers won't feel so new and I can weld some bungs into them lol.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2179074
10/20/16 12:13 PM
10/20/16 12:13 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They offer a clamp on style reader many use. I usually go by O2 readings but I finally welded two bungs (4 and 6) to get my feet wet this year
[Re: Cuda_Mike]
#2179494
10/21/16 12:06 AM
10/21/16 12:06 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I would really try to put one in #7 as I already suggested for those reasons, put the other one in the easiest one on the passenger side If you wanted to pull the headers off the car and have bungs welded into all eight pipes you could move the probes around and see what they all show at part throttle and at WOT Will your system EGT record and play back or transfer the stored information to a viewable device like a laptop? I bought a LM1 years ago and use to record a run and then load it onto my laptop to replay the results on a bigger screen at my pleasure
[Re: Monte_Smith]
#2179557
10/21/16 01:24 AM
10/21/16 01:24 AM
Bad340fish
Tulsa OK
You can't tune a gas motor, ESPECIALLY at idle with EGTs. Plus what would you tune it to? I have stuff that runs at 1200 and stuff that runs at 1600. It's just a number I would want it more for cylinder balance than anything else. With pump gas and street driving plug reading is tough, and 8 EGT readings could let you see a potential fuel delivery problem before anything else. I can adjust injector trim per cylinder but its just kind of a guess without either 8 02s $$$$$$$$ or 8 EGT $$$ lol.
[Re: Monte_Smith]
#2179600
10/21/16 07:22 AM
10/21/16 07:22 AM
gdonovan
Oakdale CT
You can't tune a gas motor, ESPECIALLY at idle with EGTs. Agreed. As someone suggested, you can always weld in 8 bungs and move the sensors about. In theory, in 4 WOT passes you would know which cylinders run lean.
