Inline trans filter #2178527
10/19/16 01:17 PM
10/19/16 01:17 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I have been using a generic inline.. filter 3 inch. 3/4 Inlet
. Is it possible I'm using too restrictive of a filter causing excessive heat in the trans.. what filter you guys successfully using.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Inline trans filter [Re: WHITEDART] #2178536
10/19/16 01:26 PM
10/19/16 01:26 PM
bean town ....Ca
W
W
bean town ....Ca
I found this on summit's website.. I have been grabbing off-the-shelf at O'Reilly anything that would fit.. I'm not so sure that was a good idea
Re: Inline trans filter [Re: WHITEDART] #2178541
10/19/16 01:34 PM
10/19/16 01:34 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why do you think you need a filter other than the one in the pan?
Re: Inline trans filter [Re: Monte_Smith] #2178545
10/19/16 01:39 PM
10/19/16 01:39 PM
bean town ....Ca
W
W
bean town ....Ca
when I was bracket racing the car with a 904.. it seemed to help greatly keep the trans clean... I recently switched over to a ProGlide.. and maybe an inline filter isn't necessary I do not know..? Honestly I was hoping for some feedback..
Re: Inline trans filter [Re: WHITEDART] #2178559
10/19/16 02:00 PM
10/19/16 02:00 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A RACE trans, usually with tight and or high stall converters, need to move a lot of fluid to keep heat down. That said, any external filter has to be placed in the cooler circuit. A circuit that in itself is somewhat restrictive depending on mods. Adding a filter here, to me would only increase that restriction. Most RACE glides these days have the cooler circuit modified to just dump the fluid back into the pan in lieu of using the "In" port on the case. So if your plumbing is utilizing the entire cooler circuit, that could be a potential problem. You should likely consult with your trans builder and see what HE says. I know on ours, the "In" port is completely blocked off
Re: Inline trans filter [Re: Monte_Smith] #2178648
10/19/16 03:58 PM
10/19/16 03:58 PM
bean town ....Ca
W
W
bean town ....Ca
Thanks this is what I was thinking
Re: Inline trans filter [Re: WHITEDART] #2178718
10/19/16 07:22 PM
10/19/16 07:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look at the orifice sizes in the case and compare them to the orifices in the filter. I'd say the major restriction is in the case orifices, not anything downstream.
Re: Inline trans filter [Re: WHITEDART] #2178800
10/19/16 10:11 PM
10/19/16 10:11 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A filter in the line leading to the cooler prevents it from collecting debris.
Boffin Emeritus
Re: Inline trans filter [Re: polyspheric] #2179774
10/21/16 03:14 PM
10/21/16 03:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And, since the fluid returning from the cooler is the main lube circuit, a filter isn't a bad idea.
Re: Inline trans filter [Re: WHITEDART] #2180235
10/22/16 11:28 AM
10/22/16 11:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kids 62 300 came from factory with an inline filter.It was on the return line.IIRC he still has one or two OE ones left.It wasnt a big filter either.Looked like a large fuel filter.Rocky
Chrysler Firepower
Re: Inline trans filter [Re: therocks] #2180246
10/22/16 11:49 AM
10/22/16 11:49 AM
moparx Offline
moparx  Offline
at one time, wix had those, but looking in my master catalog, i can't find the number. i'm seeing a guy later this morning that has a wix transmission filter chart on the wall, and i think that filter is on there. i just called him. for 5/16" line size : #58964 for 7/16" line size : 58963. hope this helps.
beer
Re: Inline trans filter [Re: WHITEDART] #2180325
10/22/16 02:25 PM
10/22/16 02:25 PM
I had a old inline small Oberg screen filter on my Duster trans mounted in the left front wheel well inline with the tranny cooler up
