Prothane Strut Rod Bushings #2171861
10/11/16 12:34 AM
10/11/16 12:34 AM
Polson, MT
DoctorDiff Offline OP
Polson, MT
Does anyone have feedback on Prothane Mopar strut rod busings?
Do they fit A, B and E body K-members and strut rods correctly?
Are they durable, or do they disintegrate prematurely?
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2172360
10/11/16 07:27 PM
10/11/16 07:27 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Cass -- your PM box is over the limit... maybe clear some out?
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2173118
10/12/16 08:10 PM
10/12/16 08:10 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Cass, I have poly strut bushes from Firm Feel, have had them in the car (E body)now for a couple of years and about 5000 miles, no issues at all if that helps
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2173129
10/12/16 08:43 PM
10/12/16 08:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He asked about Prothane bushings.
Are the FF ones Prothane?
Don't be the exception.
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2173249
10/12/16 11:22 PM
10/12/16 11:22 PM
Polson, MT
Polson, MT
Prothane, Energy Suspension and Whiteline all claim their poly strut rod bushings fit '67-'76 A-bodies, '66-'72 B-bodies and '70-'74 E-bodies.
I don't see how 1 part number from each company can cover all these vehicles.
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2173274
10/12/16 11:46 PM
10/12/16 11:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I can tell you that whatever poly bushing I bought for my 65 A, I want to say Energy Suspension ones but am not 100% sure, are too thick. And yes they were claimed to fit.
Funny thing is, Moog lists the improved design as the same for the 65 or 72 A bodies, but Energy shows different numbers and substantially different designs, RockAuto source.
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2177925
10/18/16 05:35 PM
10/18/16 05:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm thinking that, if the hole in the k-member and the rod configuration at the front is the same, they should interchange.
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2178379
10/19/16 03:28 AM
10/19/16 03:28 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
An early Barracuda autocrosser showed how the poly strut rod bushings sold at the time for A-bodies are too thick. They would fit, but pushed the LCA back. He just cut the back one down to the proper size.
Re: Prothane Strut Rod Bushings [Re: 375inStroke] #2178660
10/19/16 04:42 PM
10/19/16 04:42 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Usage of "adjustable" stock-type strut rods (see Firm Feel, others) should allow correction to the location action of the strut rod/LCA.
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2178860
10/19/16 11:41 PM
10/19/16 11:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Use of the proper thickness strut rod bushing saves the cost of an adjustable strut rod crutch.
Re: Prothane Strut Rod Bushings [Re: DoctorDiff] #2195550
11/13/16 02:14 AM
11/13/16 02:14 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Exactly. Here's some dimensions from my 67 A. http://www.heritech.org/cuda/bushings.html
Re: Prothane Strut Rod Bushings [Re: Mattax] #2197417
11/16/16 05:14 PM
11/16/16 05:14 PM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
Glad you chimed in. Yours is the page I was looking for. Has that modification worked out well?
Re: Prothane Strut Rod Bushings [Re: 375inStroke] #2197849
11/17/16 10:38 AM
11/17/16 10:38 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Yes. Still in there, same pieces. I'm not particularly hard on brakes but lots of miles, some pretty rough. Had the lower control arms off once since doing that to replace lower control bushings. I think I did a mock up check of the strut rod assembly, but the strut rod bushing assembly went back the way I had it.
I think Steve had some more pictures of the various replacement bushings including some with thickness measurements. All I can advise is mock it up, measure it and then fit the bushings as needed or use an adjustable length strut rod.
Sorry I'm not on the BB or forums much anymore, but always glad to share what I can.
addendum: The slicing was done with the aid of a wood lathe. The bushings were supported in the lathe by a short turned wood shaft with a shoulder.
