Re: Prothane Strut Rod Bushings
[Re: DoctorDiff]
#2172360
10/11/16 07:27 PM
10/11/16 07:27 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Cass -- your PM box is over the limit... maybe clear some out?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: DoctorDiff]
#2173129
10/12/16 08:43 PM
10/12/16 08:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
He asked about Prothane bushings.
Are the FF ones Prothane?
[Re: DoctorDiff]
#2173274
10/12/16 11:46 PM
10/12/16 11:46 PM
Supercuda
About to go away
About to go away
up yours
I can tell you that whatever poly bushing I bought for my 65 A, I want to say Energy Suspension ones but am not 100% sure, are too thick. And yes they were claimed to fit.
Funny thing is, Moog lists the improved design as the same for the 65 or 72 A bodies, but Energy shows different numbers and substantially different designs, RockAuto source.
[Re: DoctorDiff]
#2177925
10/18/16 05:35 PM
10/18/16 05:35 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm thinking that, if the hole in the k-member and the rod configuration at the front is the same, they should interchange.
[Re: 375inStroke]
#2178660
10/19/16 04:42 PM
10/19/16 04:42 PM
Mopar Mitch
Usage of "adjustable" stock-type strut rods (see Firm Feel, others) should allow correction to the location action of the strut rod/LCA.
Mopar Mitch
[Re: DoctorDiff]
#2178860
10/19/16 11:41 PM
10/19/16 11:41 PM
Supercuda
About to go away
About to go away
up yours
Use of the proper thickness strut rod bushing saves the cost of an adjustable strut rod crutch.
[Re: DoctorDiff]
#2195550
11/13/16 02:14 AM
11/13/16 02:14 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Prothane, Energy Suspension and Whiteline all claim their poly strut rod bushings fit '67-'76 A-bodies, '66-'72 B-bodies and '70-'74 E-bodies.
I don't see how 1 part number from each company can cover all these vehicles. Exactly. Here's some dimensions from my 67 A. http://www.heritech.org/cuda/bushings.html
[Re: Mattax]
#2197417
11/16/16 05:14 PM
11/16/16 05:14 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
I don't see how 1 part number from each company can cover all these vehicles. Exactly. Here's some dimensions from my 67 A. http://www.heritech.org/cuda/bushings.html Glad you chimed in. Yours is the page I was looking for. Has that modification worked out well?
[Re: 375inStroke]
#2197849
11/17/16 10:38 AM
11/17/16 10:38 AM
Mattax
Phila. Pa.
Has that modification worked out well? Yes. Still in there, same pieces. I'm not particularly hard on brakes but lots of miles, some pretty rough. Had the lower control arms off once since doing that to replace lower control bushings. I think I did a mock up check of the strut rod assembly, but the strut rod bushing assembly went back the way I had it. I think Steve had some more pictures of the various replacement bushings including some with thickness measurements. All I can advise is mock it up, measure it and then fit the bushings as needed or use an adjustable length strut rod. Sorry I'm not on the BB or forums much anymore, but always glad to share what I can. addendum: The slicing was done with the aid of a wood lathe. The bushings were supported in the lathe by a short turned wood shaft with a shoulder.
