wanted some opinions about hp on my engine. it is a .030 over 440 je domed pistons, eagle h-beams, stock crank, 11.0-1 CR, following parts from hughes engines...stage 2 plus heads (2.19 intake w/extra intake porting), hughes 3237 hyd cam (.576 .587 dur @ .50.232 .237, 110 LSA) , 1.6 rockers, performer rpm intake w/hughes porting, 1 7/8 stahl headers and 850 bg gold claw. stage 1 engines from hughes make about 500-550 hp while the stage 2 seem to make 550-600. my motor seems to be a bit different kind of a stage 1 1/2. since the cam has to pull 15'' of vac. so what do ya guys think hp and torque range would be???
