Hemi Auto Trans Dipstick & Tube
#2175616
10/16/16 12:56 AM
10/16/16 12:56 AM
Posts: 92 Iowa
Davtona
Iowa
I've been looking for a 1969 original transmission dipstick and tube for a 426 Hemi automatic transmission. Everything I have been seeing is a one piece style dipstick. Including what are supposed to be Mopar original pieces. I seem to remember a Hemi dipstick being 2 pieces riveted together. Am I correct on this? Anyone have any pictures? I'm interested in original parts only no reproduction parts.
Re: Hemi Auto Trans Dipstick & Tube
[Re: ratroaster]
#2176990
10/17/16 03:52 PM
10/17/16 03:52 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here you go....this is a '70. Would you be kind enough to post some measurements?
[Re: John_Kunkel]
#2177084
10/17/16 06:10 PM
10/17/16 06:10 PM
Posts: 318 Iowa
ratroaster
Iowa
Would you be kind enough to post some measurements? 18 1/2" overall. 16" from the end to the rubber grommet stop.
[Re: NANKET]
#2178128
10/18/16 10:07 PM
10/18/16 10:07 PM
Posts: 92 Iowa
Davtona
Iowa
So they took a big block dipstick and shortened and modified it to fit the Hemi application? Looks like 2 cuts were made judging by the slightly different widths of the stick at the joint. Then the center piece was discarded and the remaining 2 riveted together. Seems like a lot of labor intensive tedious work when one the correct length could have been designed and built. Also considering they apparently designed and built a special tube for it.
[Re: Davtona]
#2178315
10/19/16 01:13 AM
10/19/16 01:13 AM
John_Kunkel
Rio Linda, CA
Big block, small block use the same dipstick but the tubes come in several different shapes. I agree that, for the small number of Hemi automatics, it was cheaper to shorten rather than make the dipstick from scratch.
