NV4500 to a 440 #2175260
10/15/16 02:02 PM
10/15/16 02:02 PM
Wills Point, Texas
Hugh Jorgan Offline OP
Wills Point, Texas
Has anyone here mated a NV4500 behind a 440 in a pickup? Just curious.
Re: NV4500 to a 440 [Re: Hugh Jorgan] #2175430
10/15/16 08:13 PM
10/15/16 08:13 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i am thinking you could do it---use a gas nv4500---you might have to make a flat adapter plate for between the bellhousing and the tranny-----i put an 833 behind a v10 motor and used the cummins getrag bellhousing and a 3/4 inch thick aluminum plate as the adapter---measure twice.....
Re: NV4500 to a 440 [Re: savoy64] #2175453
10/15/16 08:46 PM
10/15/16 08:46 PM
Wills Point, Texas
Wills Point, Texas
This was a 94 Cummins trans and I have a scattershield or will mod a BB truck bell. I need to figure out what I can use for a clutch fork.
Re: NV4500 to a 440 [Re: Hugh Jorgan] #2175655
10/16/16 02:16 AM
10/16/16 02:16 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think the cummins input shaft is longer than the gas one---the good news is it is easy to swap the inputs out---and again that will depend on your measurements...
Re: NV4500 to a 440 [Re: Hugh Jorgan] #2179265
10/20/16 05:51 PM
10/20/16 05:51 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Lakewood sold a bellhousing for this.
Moparlee
