4 core radiator on 69 b body #2175120
10/15/16 10:37 AM
10/15/16 10:37 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
radiator is to thick to add fan spacer,what size spacer to run with 4 core radiator. thanks
Re: 4 core radiator on 69 b body [Re: moparpro] #2175277
10/15/16 02:38 PM
10/15/16 02:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
going to need a bit more info, what car, motor etc. pic's would also help whistling
Re: 4 core radiator on 69 b body [Re: TJP] #2175317
10/15/16 04:33 PM
10/15/16 04:33 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
69 roadrunner,383, 4 core radiator.fan clutch is to close to radiator,not sure what distance i should have from fan clutch to radiator? thanks
Re: 4 core radiator on 69 b body [Re: moparpro] #2175319
10/15/16 04:48 PM
10/15/16 04:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
2947 Hayden is a new ,special short HD fan clutch for mopars.
Re: 4 core radiator on 69 b body [Re: CSK] #2175663
10/16/16 02:25 AM
10/16/16 02:25 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Re: 4 core radiator on 69 b body [Re: Big_E] #2175682
10/16/16 03:57 AM
10/16/16 03:57 AM
I'd want ~7/8" from the closest part to the rad. You said B body so I am assuming BB. You might be able to press the pump cross a bit rearward & how far might depend on how close the pulley is to the 4 bolts and you can get button head bolts that are much thinner. (support the shaft on the other side when/if pressing). iirc on a BB you could mill the pump housing mounting faces so the pump sits further rearward. 440source & speedway mtrs have pump and crank dampener shims. EDIT yes if the Hayden will take care of you then that'd be an easy fix
Re: 4 core radiator on 69 b body [Re: Big_E] #2176760
10/17/16 11:49 AM
10/17/16 11:49 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thanks
