A leak free 727?? #2175092
10/15/16 08:37 AM
10/15/16 08:37 AM
tboomer Offline OP
tboomer  Offline OP
My 64 has a puddle of tranny fluid under it. It appears to be weeping around some of the bolts. I also hope the front pump seal isn't out. I am thinking that I should have the pan gasket changed and maybe put a new deep pan on it. So what is everyone using for a pan? I see Trick Flow has one at a good price. Thanks! Ted wave
Re: A leak free 727?? [Re: tboomer] #2175093
10/15/16 08:48 AM
10/15/16 08:48 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Whatever you use, DO NOT use a chrome pan. I have seen more chrome transmission and oil pans leak on all kinds of cars, than anything else.
[image][/image]
Re: A leak free 727?? [Re: sgcuda] #2175095
10/15/16 08:53 AM
10/15/16 08:53 AM
tboomer Offline OP
tboomer  Offline OP
Thanks Ken....I would never use a chrome pan. wave
Re: A leak free 727?? [Re: tboomer] #2175097
10/15/16 08:57 AM
10/15/16 08:57 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I'm using the Mopar Performance deep pan with Fel-Pro TOS18583 gasket.
72 Plymouth Roadrunner 11.08@123.25
Re: A leak free 727?? [Re: tboomer] #2175116
10/15/16 10:20 AM
10/15/16 10:20 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I have an finned aluminium deep pan and use a re-useable pan gasket, no leaks whatsoever. Can't remember the manufacturers but Todd Marsh got them for me. HTH's
Re: A leak free 727?? [Re: Tig] #2175141
10/15/16 11:16 AM
10/15/16 11:16 AM
tboomer Offline OP
tboomer  Offline OP
Thanks fellas! How much extra capacity do we need? wave
Re: A leak free 727?? [Re: tboomer] #2175142
10/15/16 11:16 AM
10/15/16 11:16 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
bone yard.... well ok, a core went back with no pan smile 46RE stock pan, mopar reusable gasket. torqued to 125 inlb... been on/off several times over the years for service and no leaks. Another godsend was using a dipstick tube with the "GM" style seal (mopar adopted that on later truck models).
Re: A leak free 727?? [Re: tboomer] #2175149
10/15/16 11:25 AM
10/15/16 11:25 AM
tboomer Offline OP
tboomer  Offline OP
Jay...The GM filler tube fits on a 727?? And a 46RE pan will fit? How much extra capacity? shruggy Thanks!
Re: A leak free 727?? [Re: tboomer] #2175151
10/15/16 11:28 AM
10/15/16 11:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Finned aluminum works well. So does the factory (or aftermarket copy) of the 518 pan. My 518 replacement is still using the same reusable gasket after many inspections. Many times the cables leak at the crimps. I have the fix. Plugging the front vent and relocating helps the bell housing leaks. The park cable adapter is often warped. It can be stoned flat.
Doug
Re: A leak free 727?? [Re: dvw] #2175176
10/15/16 12:02 PM
10/15/16 12:02 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Doug
Great info Would you have any pics of your alterations?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: A leak free 727?? [Re: tboomer] #2175189
10/15/16 12:24 PM
10/15/16 12:24 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Does the superperformace guy make a pan gasket?
Re: A leak free 727?? [Re: Kam*Kuda] #2175200
10/15/16 12:41 PM
10/15/16 12:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
The cables can be repaired with heat shrink for wiring. Use the type with the glue. I have it if you need it.
Doug
Re: A leak free 727?? [Re: dvw] #2176705
10/17/16 10:04 AM
10/17/16 10:04 AM
moparx Offline
moparx  Offline
where have you found the best source for the marine grade heat shrink ? i am ready to re-stock my selection of sizes and colors, and would prefer to get 2 or 4ft sections if possible.
beer
Re: A leak free 727?? [Re: tboomer] #2176770
10/17/16 12:03 PM
10/17/16 12:03 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Can't say on the capacity... the 47/48RE pans are slightly deeper than the MP deep pans they had.
In the early 90's we cut the end off our 727 dipstick tube and brazed on a chevy end and used their seal. Worked great! Mopar went to a similar style in the late 90's on their trucks and it, unlike that stupid oring, didn't leak either.
....just like this:
Re: A leak free 727?? [Re: tboomer] #2176791
10/17/16 12:33 PM
10/17/16 12:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The locking dipstick/tube I bought from Cope has the gm style rubber seal on it. I'm using the late pan on my 727, IIRC it came with the filter spacer from Mancini.
Re: A leak free 727?? [Re: tboomer] #2176999
10/17/16 03:59 PM
10/17/16 03:59 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
People beat up the tube, by working it back and forth, as opposed to pulling straight up, and slightly turning to break the o-ring loose.
