thread sealer on pick up tube? #2173502
10/13/16 11:41 AM
10/13/16 11:41 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Do you guys use thread sealer or lock tite on pick up tube threads? 400 block.
Re: thread sealer on pick up tube? [Re: mopar dave] #2173508
10/13/16 11:45 AM
10/13/16 11:45 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have used gasket shellac
Re: thread sealer on pick up tube? [Re: mopar dave] #2173575
10/13/16 01:14 PM
10/13/16 01:14 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
There is a slight taper on the threads so you don't need any sealer.
Re: thread sealer on pick up tube? [Re: mopar dave] #2173632
10/13/16 02:28 PM
10/13/16 02:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
BS !! ALL pipe threads are tapered - but if you look at any joint done by a pro - gas, water or oil, they use a thread sealant.
The sealant ensures a good seal when you have to back off the fitting for alignment and it also ensures the fitting will stay put.
Go with the sealant. There is a product on the market now called "Pipe Goop". Its clear, will solidify somewhat and is easy to remove if the joint ever has to come apart. Its way less messy than the white pipe sealant.
Re: thread sealer on pick up tube? [Re: mopar dave] #2173635
10/13/16 02:34 PM
10/13/16 02:34 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I use high temp liquid teflon on mine, seems to work good for me
Re: thread sealer on pick up tube? [Re: mopar dave] #2173672
10/13/16 03:08 PM
10/13/16 03:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use liquid teflon pipe dope, sparingly, not dripping tsk
Re: thread sealer on pick up tube? [Re: Cab_Burge] #2173697
10/13/16 03:40 PM
10/13/16 03:40 PM
dogdays Offline
dogdays  Offline
NOT All pipe threads are tapered. There is a standard for straight pipe threads, NPS. I believe the oil pickup tube is NPS.
I ran into this pipe thread overseas. It seems to be more common over there. Sealing a straight thread pipe involves using sealer or something like hemp, turning the pipe into the fitting, then locking it down with a jam nut. This jam nut is supposed to put tension on the joint and get the threads to push against each other, creating a mechanical seal.
http://www.regalcuttingtools.com/products/taps/pipe-taps/straight-pipe-taps/nps-straight-pipe-taps
I would recommend Loctite 567 or 545. They both seal at higher temperatures, 300 and 400F and can be taken apart with hand tools.
R.
Re: thread sealer on pick up tube? [Re: mopar dave] #2173698
10/13/16 03:40 PM
10/13/16 03:40 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks guys. I will get some thread sealer then.
Re: thread sealer on pick up tube? [Re: mopar dave] #2173725
10/13/16 04:15 PM
10/13/16 04:15 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
The pickup tube is tapered.
Pipe threads that are tapered seal themselves so no pipe SEALER is required on them.
However, pipe lubricant , such as teflon, is required to achieve the recommended torque to seal the pipe. Teflon and other thread lubricants will not seal but will allow proper torque compared to bare threads.
A sealer would be used in straight threads, such as header bolts open to a water jacket, that have no taper and require a sealant to keep them from leaking.
Re: thread sealer on pick up tube? [Re: DJVCuda] #2173730
10/13/16 04:20 PM
10/13/16 04:20 PM
Mt Morris Michigan
Mt Morris Michigan
I do have a roll of Teflon tape in the tool box. Guess I'm all set. Thanks
Re: thread sealer on pick up tube? [Re: mopar dave] #2173734
10/13/16 04:26 PM
10/13/16 04:26 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I wouldn't use that. Not to be a naysayer but the risk of that getting into the oiling system is too great for me. I would use liquid teflon or nothing.
Re: thread sealer on pick up tube? [Re: mopar dave] #2173886
10/13/16 06:37 PM
10/13/16 06:37 PM
JohnRR Offline
JohnRR  Offline
NO!
Re: thread sealer on pick up tube? [Re: JohnRR] #2173894
10/13/16 06:48 PM
10/13/16 06:48 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Never used anything, never will.
'63 Dodge 330
11.19 @ 121 mph
Re: thread sealer on pick up tube? [Re: JohnRR] #2174009
10/13/16 08:47 PM
10/13/16 08:47 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
iagree
Indian Head gasket shellac
Re: thread sealer on pick up tube? [Re: mopar dave] #2174021
10/13/16 09:06 PM
10/13/16 09:06 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What did the factory use? They built more engines than we will, and they warrantied them! LOL
Re: thread sealer on pick up tube? [Re: NANKET] #2174029
10/13/16 09:15 PM
10/13/16 09:15 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Next time I build an engine to factory specs, I'll consider that, but I don't have the budget to replace engines like the factory does.
Re: thread sealer on pick up tube? [Re: mopar dave] #2174054
10/13/16 09:47 PM
10/13/16 09:47 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The factory original pick-up tubes that I have, and had in the past are not tapered, they are straight pipe thread. After market pick-ups seem to be tapered. The threads in the blocks are tapered pipe thread. The threads are designed to seal without sealer but need to have lubricant/sealer to help assure good joint make-up.
Re: thread sealer on pick up tube? [Re: mopar dave] #2174092
10/13/16 10:25 PM
10/13/16 10:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm wondering why its called "Teflon pipe sealant" instead of "Teflon pipe lubricant".
Re: thread sealer on pick up tube? [Re: mopar dave] #2174147
10/13/16 11:17 PM
10/13/16 11:17 PM
AndyF Offline
AndyF  Offline
It can't really go anywhere once the pan is on but you don't want to be sucking air in the threads so I use a little dab of sealer. I use a low strength Loctite blue to do the job but there are probably a bunch of things that will work.
Re: thread sealer on pick up tube? [Re: BSB67] #2174224
10/14/16 12:29 AM
10/14/16 12:29 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By BSB67
The threads are designed to seal without sealer....
My bad, sealer needed
