Re: thread sealer on pick up tube?
[Re: mopar dave]
#2173632
10/13/16 02:28 PM
10/13/16 02:28 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
There is a slight taper on the threads so you don't need any sealer. BS !! ALL pipe threads are tapered - but if you look at any joint done by a pro - gas, water or oil, they use a thread sealant. The sealant ensures a good seal when you have to back off the fitting for alignment and it also ensures the fitting will stay put. Go with the sealant. There is a product on the market now called "Pipe Goop". Its clear, will solidify somewhat and is easy to remove if the joint ever has to come apart. Its way less messy than the white pipe sealant.
[Re: mopar dave]
#2173635
10/13/16 02:34 PM
10/13/16 02:34 PM
Posts: 5,166 CT
GTX MATT
CT
I use high temp liquid teflon on mine, seems to work good for me
[Re: Cab_Burge]
#2173697
10/13/16 03:40 PM
10/13/16 03:40 PM
dogdays
NOT All pipe threads are tapered. There is a standard for straight pipe threads, NPS. I believe the oil pickup tube is NPS. I ran into this pipe thread overseas. It seems to be more common over there. Sealing a straight thread pipe involves using sealer or something like hemp, turning the pipe into the fitting, then locking it down with a jam nut. This jam nut is supposed to put tension on the joint and get the threads to push against each other, creating a mechanical seal. http://www.regalcuttingtools.com/products/taps/pipe-taps/straight-pipe-taps/nps-straight-pipe-tapsI would recommend Loctite 567 or 545. They both seal at higher temperatures, 300 and 400F and can be taken apart with hand tools. R.
[Re: mopar dave]
#2173734
10/13/16 04:26 PM
10/13/16 04:26 PM
Posts: 5,166 CT
GTX MATT
CT
I do have a roll of Teflon tape in the tool box. Guess I'm all set. Thanks I wouldn't use that. Not to be a naysayer but the risk of that getting into the oiling system is too great for me. I would use liquid teflon or nothing.
[Re: JohnRR]
#2173894
10/13/16 06:48 PM
10/13/16 06:48 PM
Posts: 4,700 Wichita
GY3
Wichita
Never used anything, never will.
[Re: NANKET]
#2174029
10/13/16 09:15 PM
10/13/16 09:15 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
What did the factory use? They built more engines than we will, and they warrantied them! LOL Next time I build an engine to factory specs, I'll consider that, but I don't have the budget to replace engines like the factory does.
[Re: BSB67]
#2174224
10/14/16 12:29 AM
10/14/16 12:29 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
The threads are designed to seal without sealer.... My bad, sealer needed
