Discontinued Magnum R/T Head #P5007140 vs P5155469 #1879082
07/27/15 01:30 PM
07/27/15 01:30 PM
Belmar, NJ
mr5racing Offline OP
Belmar, NJ
We are trying to run an asphalt modified against a field of chevy spec motors with Dart Iron Eagle 200's. We have a lightweight bottom end vs the heavy chevys. My question is our rules only allow the Magnum R/T 7140 head that I cannot find anywhere. Mopar Performance came out with its replacement the P5155469. The problem is we are allowed 180cc head no modifications and the new head is 172cc. the old head was flowed at Shady Dell at 245@ 28in of water. Has anyone flowed these newer performance heads 5469? if im going to petition the tech inspectors to allow me to run the newer head we may have to change pistons to get to the rule 10:1 or cut the heads and manifold to fit. I know im looking for a needle in a haystack looking for the old R/T heads but Im looking.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #1879231
07/27/15 04:04 PM
07/27/15 04:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Kinda hard to tell anything from the pics on the sellers websites. Some say AL some say iron, some look like stock magnums some look like an EQ so unless someone posts an actual picture it would be hard to determine what you really get.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: HotRodDave] #1879409
07/27/15 07:26 PM
07/27/15 07:26 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I don`t know much about them but I got a Jegs sale email alert and it said they had a Magnum replacement head, I believe it said its a replacement for the discontinued M/P Magnum head. Maybe someone here knows more about them.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: 11secdart] #1880113
07/28/15 03:49 PM
07/28/15 03:49 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I saw that too. I believe those are the EQ (Enginequest) heads.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #1880127
07/28/15 04:19 PM
07/28/15 04:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There is a pair in the for sale section right now, if I had any money I would have called the guy before telling you.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #1880140
07/28/15 04:36 PM
07/28/15 04:36 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
How come the Chevies can run an aftermarket head and you can't?? If it's a "cast iron" only rule then the RHS or EQ heads are the ticket. You can enhance the valve and VJ with the as supplied 1.92 intakes and flow just as well.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #1880150
07/28/15 04:55 PM
07/28/15 04:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Magnum R/T heads are aftermarket.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #1890452
08/12/15 06:46 PM
08/12/15 06:46 PM
Belmar, NJ
Belmar, NJ
why because the modified division for affordability decided to go to w GM spec engine 12:1 with Dart Iron Eagle 200cc heads that flow 262 cfm with a heavy bottom end. the old chevy rules allowed an OEM replacement World Product head that was nothing special at 10:1. they stated that the spec head would set the bar. that left all other engines as a dying breed. very few could afford to rebuild a new spec engine but it did add to the car counts. now that the field is healthy they threw that "set the bar" out the window and now allow the old 10:1 chevy rule engine to bolt on the Dart Iron Eagles too and run at 11:1. Now the Mopar is a whole different animal. you have an unlimited crank weight rule like the old chevy rule engines, lightweight rods and pistons, bigger stroke, bigger lifters and bigger Cu. In. the last Mopar to run in the old rules could of won every week. to slow that down when they approved the Dart Iron Eagles they allowed the Mopar to run the R/T head at 1.925 intake valve and force the mopar to run the M-1 dual plane intake and 10:1 vs the chevy Edelbrock performer 7101. Im not sure what kind of power we are looking at but ive seen HP no.s on the dart iron eagles between 400-450hp. im hoping with more low end torque and less rpm needed we can get this motor on the dyno and see where we are at.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #1890456
08/12/15 06:49 PM
08/12/15 06:49 PM
Belmar, NJ
Belmar, NJ
Im still looking for a set of these heads and have found a few sets that need 1.925 seats. So if you have one or two laying around or a set on a bad motor let me know. I don't have 25 posts yet to respond to private messages, still have a few to go still. so you can reach me at 732-539-6040. thanks for any help we get to get out there and get Mopar to the front of an all Chevy field.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #2153096
09/12/16 03:25 PM
09/12/16 03:25 PM
Belmar, NJ
Belmar, NJ
Well its officially a dead issue now. Based on the chevy head and manifold rules we arent going to be able to make enough power with the Magnum R/T heads. So i sold the ultralight 365 short block and now im selling the rare Magnum R/T heads. PM message me if you want to buy them.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #2153222
09/12/16 06:50 PM
09/12/16 06:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a set of those heads on my 318. Have 2.02 valves in them
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #2156488
09/17/16 10:30 PM
09/17/16 10:30 PM
Central Mississippi
mopar97 Offline
mopar97  Offline
Central Mississippi
Please check your email mr5racing.
Thanx
Allen
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #2173206
10/12/16 10:43 PM
10/12/16 10:43 PM
indiana
Faulkner Offline
Faulkner  Offline
indiana
Do you still have yhe heads for sale
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #2173207
10/12/16 10:44 PM
10/12/16 10:44 PM
indiana
Faulkner Offline
Faulkner  Offline
indiana
Interested in the heads
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469 [Re: mr5racing] #2173565
10/13/16 12:59 PM
10/13/16 12:59 PM
Belmar, NJ
Belmar, NJ
yes i still have them just confirmed. engine builder says sell them to the best offer on them. I paid $1100 for these heads recently because i had to have them.
