Discontinued Magnum R/T Head #P5007140 vs P5155469
#1879082
07/27/15 01:30 PM
07/27/15 01:30 PM
Posts: 25 Belmar, NJ
mr5racing
Belmar, NJ
We are trying to run an asphalt modified against a field of chevy spec motors with Dart Iron Eagle 200's. We have a lightweight bottom end vs the heavy chevys. My question is our rules only allow the Magnum R/T 7140 head that I cannot find anywhere. Mopar Performance came out with its replacement the P5155469. The problem is we are allowed 180cc head no modifications and the new head is 172cc. the old head was flowed at Shady Dell at 245@ 28in of water. Has anyone flowed these newer performance heads 5469? if im going to petition the tech inspectors to allow me to run the newer head we may have to change pistons to get to the rule 10:1 or cut the heads and manifold to fit. I know im looking for a needle in a haystack looking for the old R/T heads but Im looking.
Re: Discontinued Magnum R/T Head #P5007140 vs P5155469
[Re: mr5racing]
#1879231
07/27/15 04:04 PM
07/27/15 04:04 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Kinda hard to tell anything from the pics on the sellers websites. Some say AL some say iron, some look like stock magnums some look like an EQ so unless someone posts an actual picture it would be hard to determine what you really get.
[Re: HotRodDave]
#1879409
07/27/15 07:26 PM
07/27/15 07:26 PM
Posts: 4,977 new jersey usa
11secdart
new jersey usa
I don`t know much about them but I got a Jegs sale email alert and it said they had a Magnum replacement head, I believe it said its a replacement for the discontinued M/P Magnum head. Maybe someone here knows more about them.
[Re: 11secdart]
#1880113
07/28/15 03:49 PM
07/28/15 03:49 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
I saw that too. I believe those are the EQ (Enginequest) heads.
[Re: mr5racing]
#1880127
07/28/15 04:19 PM
07/28/15 04:19 PM
HotRodDave
Kalispell Mt.
There is a pair in the for sale section right now, if I had any money I would have called the guy before telling you.
[Re: mr5racing]
#1880140
07/28/15 04:36 PM
07/28/15 04:36 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
We are trying to run an asphalt modified against a field of chevy spec motors with Dart Iron Eagle 200's. We have a lightweight bottom end vs the heavy chevys. My question is our rules only allow the Magnum R/T 7140 head that I cannot find anywhere. Mopar Performance came out with its replacement the P5155469. The problem is we are allowed 180cc head no modifications and the new head is 172cc. the old head was flowed at Shady Dell at 245@ 28in of water. Has anyone flowed these newer performance heads 5469? if im going to petition the tech inspectors to allow me to run the newer head we may have to change pistons to get to the rule 10:1 or cut the heads and manifold to fit. I know im looking for a needle in a haystack looking for the old R/T heads but Im looking. How come the Chevies can run an aftermarket head and you can't?? If it's a "cast iron" only rule then the RHS or EQ heads are the ticket. You can enhance the valve and VJ with the as supplied 1.92 intakes and flow just as well.
[Re: mr5racing]
#1880150
07/28/15 04:55 PM
07/28/15 04:55 PM
HotRodDave
Kalispell Mt.
Magnum R/T heads are aftermarket.
[Re: mr5racing]
#2153222
09/12/16 06:50 PM
09/12/16 06:50 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I have a set of those heads on my 318. Have 2.02 valves in them
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mr5racing]
#2156488
09/17/16 10:30 PM
09/17/16 10:30 PM
Posts: 235 Central Mississippi
mopar97
Central Mississippi
Please check your email mr5racing. Thanx Allen
Mopar born, Mopar breed, when I die, call me Mopar dead!
