New best in ultra street trim
#2172555
10/11/16 11:42 PM
10/11/16 11:42 PM
Posts: 4,690 On the parachute mount
n20mstr
Been working on a lot of things and testing a lot. Trying to creep up on it. Went 5.10 @ 140 , then went to clay city for josh race and slowed the car down 5 mph .... Trying to run it too lean. Car is still 100lbs over weight and no where near where it should be in 60 foot numbers.
....BAD A$$ STREET CAR.....
Re: New best in ultra street trim
[Re: n20mstr]
#2172623
10/12/16 01:00 AM
10/12/16 01:00 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
That's awesome to here Tony! Hope to see that bad machine at some Cecil races.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2172627
10/12/16 01:07 AM
10/12/16 01:07 AM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Nice to hear, Tony. Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: n20mstr]
#2172639
10/12/16 01:17 AM
10/12/16 01:17 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Congratulations Tony! I know you've been working your A$$ off on that thing
Are you still running gen 1 radials? What's the 60ft?
[Re: SpareParts]
#2172644
10/12/16 01:26 AM
10/12/16 01:26 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Nice keep up the good work.. I'm glad they're not that fast out here.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 1967dartgt]
#2172733
10/12/16 09:34 AM
10/12/16 09:34 AM
n20mstr
That's awesome to here Tony! Hope to see that bad machine at some Cecil races. that's the plan, but 5.10 aint cutting it there. lol Trying to at least get it in the 4.90 range....still not a front runner ! But maybe can go one round or two Tom Romeo has helped a lot with the suspension and shocks.
[Re: SpareParts]
#2172734
10/12/16 09:37 AM
10/12/16 09:37 AM
n20mstr
Are you still running gen 1 radials? What's the 60ft? im not using the gen1 radial, im using the "new" SS tire, the one that looks like a snow tire LOL I think its the same as the first gen one, but just has bigger tread on it = less contact patch ? So far the best 60 has been 1.26 about a tenth away. Have been working on getting the car A to B and trying to get the MPH up, then we will work on the 60 and getting agressive
[Re: BradH]
#2172785
10/12/16 11:25 AM
10/12/16 11:25 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
VERY nice!!!!!!!!! Congratulations.
[Re: fbs63]
#2172800
10/12/16 11:51 AM
10/12/16 11:51 AM
1967dartgt
Hilltown Pa
No pro in ultra unless you are NA
[Re: n20mstr]
#2172802
10/12/16 11:54 AM
10/12/16 11:54 AM
1967dartgt
Hilltown Pa
That's awesome to here Tony! Hope to see that bad machine at some Cecil races. that's the plan, but 5.10 aint cutting it there. lol Trying to at least get it in the 4.90 range....still not a front runner ! But maybe can go one round or two Tom Romeo has helped a lot with the suspension and shocks. The Romeo's are great, know there way around a racecar for sure. Steve helps me out with my car when it's running. And you are right ultra is crazy at Cecil.
[Re: n20mstr]
#2172889
10/12/16 01:54 PM
10/12/16 01:54 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
While I know you want power, you should be concentrating on making the car WORK. More power won't matter if you can't stick it. A tenth in 60ft would likely make that 5.10 pass a 4.95 with NO more extra power. Make what you HAVE work and then worry about what you don't have. The car won't 60ft and you know it's overweight. Both those items are robbing you of a lot of ET.
Shawn Pevlor went 4.59, maybe even quicker at SGMP. No big deal you think, because he is the man on a plate right now......UNTIL you look at the mph. He doesn't run big mph for the ETs he goes, but the car is a rocketship in the first half of the track. IT WORKS.
We have a new motor in the Buick. It really hasn't made a full, clean A-B pass yet and that's fine because that is not what I am working on. Before, even when it was fast, the graphs were junk and it only went down because the track was stellar. So the goal with new motor has been smooth application of power and smooth graphs. We have heated the tires 11 times and it has left the starting line 10 times. Our first 60ft was a 1.30 and the last 4 have been between 1.10 and 1.07, with what I will call a pretty damn soft setup. I think we can go sub 1.0s when all dialed in. Before you say it's not the same tire, I KNOW that, but there are guys on the same tire as you who are better than a tenth quicker in 60 than you and that is NOT about power. Its about power management and car setup. So even when you have enough power to run 145 or whatever number you are looking for, you will still have to manage it early, so figure that part out NOW
[Re: Monte_Smith]
#2172996
10/12/16 04:31 PM
10/12/16 04:31 PM
n20mstr
We have a new motor in the Buick. It really hasn't made a full, clean A-B pass yet and that's fine because that is not what I am working on. Before, even when it was fast, the graphs were junk and it only went down because the track was stellar. So the goal with new motor has been smooth application of power and smooth graphs. We have heated the tires 11 times and it has left the starting line 10 times. Our first 60ft was a 1.30 and the last 4 have been between 1.10 and 1.07, with what I will call a pretty damn soft setup. I think we can go sub 1.0s when all dialed in. Before you say it's not the same tire, I KNOW that, but there are guys on the same tire as you who are better than a tenth quicker in 60 than you and that is NOT about power. Its about power management and car setup. So even when you have enough power to run 145 or whatever number you are looking for, you will still have to manage it early, so figure that part out NOW 140 is the number I was looking for. You know I started with small tuneups and inferior parts. From now on I will be working on the front half and getting the weigh down.
[Re: n20mstr]
#2173102
10/12/16 07:39 PM
10/12/16 07:39 PM
1967dartgt
Hilltown Pa
Tony do you have a racepak?
