Radiator shop epoxy repair? #2171088
10/09/16 08:56 PM
10/09/16 08:56 PM
Near Reading PA USA
pinkduster Offline OP
Near Reading PA USA
When a radiator shop repairs an aluminum radiator with epoxy, what product are they using? Thoughts?
Re: Radiator shop epoxy repair? [Re: pinkduster] #2171116
10/09/16 09:22 PM
10/09/16 09:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Good question. I actually never heard of that type of repair. I have read rad manufacturers use epoxy, but it was not supposed to be a primary structural component, if I can believe what they shared. I spoke with a niche high performance epoxy manufacturer, and gave them my parameters for a solution on a radiator, <30psi pressure, <250F, and water/glycol long term exposure, constant pressure cycling. They were most concerned with the water/glycol exposure long term, seeping into the carbon fiber filament, which is not the case for a typical rad solution issue. Never got an answer that would not require testing, and that was beyond what I wanted to invest. Lets us know what you discover.
Re: Radiator shop epoxy repair? [Re: jcc] #2171350
10/10/16 09:09 AM
10/10/16 09:09 AM
IN
ahy Offline
ahy  Offline
IN
I have used JB weld for repair of copper/brass radiator tanks. It worked fine for short term repair... then I replaced the radiator. For aluminum I would try JB Aluminum weld based on the idea expansion with heat would be more similar to the radiator.
Re: Radiator shop epoxy repair? [Re: ahy] #2171353
10/10/16 09:54 AM
10/10/16 09:54 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i repaired many motor cycle gas tanks with JB never a prob with longevity.my curent rad in my daily driver is repaired with JB,going on 15 years no leaks.SURFACE PREP.
Re: Radiator shop epoxy repair? [Re: pinkduster] #2171602
10/10/16 06:16 PM
10/10/16 06:16 PM
MD
p d'ro Offline
p d'ro  Offline
MD
My stock radiator on the 67 RT is dripping a tiny bit at a seam at the top of the tank and no one in DC metro repairs radiators. I was going to sand off the paint and try to solder. Would JB weld be a better option?
Re: Radiator shop epoxy repair? [Re: p d'ro] #2171642
10/10/16 07:40 PM
10/10/16 07:40 PM
IN
ahy Offline
ahy  Offline
IN
Per my experience JB sticks well to copper/brass... but not sure about lead. It may not stick so well to the solder already there.
You could try the JB... or re-solder. Either way it would be good to have a "plan B": send the radiator out to a specialist like Glen Ray or replace it.
Re: Radiator shop epoxy repair? [Re: pinkduster] #2171995
10/11/16 10:17 AM
10/11/16 10:17 AM
Maryland
MoparMike1974 Offline
Maryland
Most epoxy will become soft when it gets hot. Although, I have used JB Weld on radiators with success. I would stick with JB Weld or Marine Tex. Any high quality epoxy should work. I use west system epoxy mixed with aluminum powder as a substitute for JB Weld. I try to stay away from the 5 minute epoxys too as they dont seem to get as hard as a slow cure epoxy.
Re: Radiator shop epoxy repair? [Re: MoparMike1974] #2172001
10/11/16 10:38 AM
10/11/16 10:38 AM
moparx Offline
moparx  Offline
i was at the local ace hardware recently, and i think i saw some high temp JB. i could be wrong [wouldn't be the first time, and certainly NOT the last .]
beer
Re: Radiator shop epoxy repair? [Re: moparx] #2172722
10/12/16 08:47 AM
10/12/16 08:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
beer
I think i saw that too.but mabey not ,i could of though. shruggy
Re: Radiator shop epoxy repair? [Re: pinkduster] #2173025
10/12/16 05:03 PM
10/12/16 05:03 PM
P
Paul_Fancsali Offline
P
JB it with clean prep and no coolant for at least 24 hours and don't do it outside with temps below 60
Re: Radiator shop epoxy repair? [Re: p d'ro] #2173053
10/12/16 05:51 PM
10/12/16 05:51 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Whats the world coming to.... LOL
That is sad though, no joke..
Re: Radiator shop epoxy repair? [Re: minivan] #2173191
10/12/16 10:19 PM
10/12/16 10:19 PM
dogdays Offline
dogdays  Offline
That's why God gave us Stop Leak.
But.....
If it's the seam between the top tank and the core this may be a clue that your core is partially plugged. I had it happen once, it just kept opening up little by little. About 2/3 of the tubes were plugged (probably from Stop Leak!).
I guess I'm saying the epoxy might solve the symptom but not cure the disease. Solder would be my choice for a leaking seam.
R.
Re: Radiator shop epoxy repair? [Re: pinkduster] #2173273
10/12/16 11:46 PM
10/12/16 11:46 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I wouldn't trust epoxy on a radiator, just solder it. It's not that dificult..
Re: Radiator shop epoxy repair? [Re: Paul_Fancsali] #2173892
10/13/16 06:46 PM
10/13/16 06:46 PM
Chicago
PurpleBeeper Offline
Chicago
Paul is correct. I have repaired radiators both ways (solder & epoxy) and both work.
1. all epoxies will chemically resist antifreeze.
2. all epoxies will be OK with roughly 300F continuous temperature.
3. Slow cure epoxies are stronger, stick better & have better chemical resistance than 5-min. epoxies.
4. all epoxies stick very well to all metals that have proper SURFACE PREPARATION as another poster mentioned... including lead. For plastic, you need a 5-min.type epoxy designed for plastic (mercaptan based pt. B)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Radiator shop epoxy repair? [Re: pinkduster] #2173941
10/13/16 07:31 PM
10/13/16 07:31 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I JB Welded a fitting that I accidentally tore off. Never had a problem. You could clean it and solder it like you're supposed to.
