Molnar rods #2171101
10/09/16 09:07 PM
10/09/16 09:07 PM
AndyF Offline OP
AndyF  Offline OP
Picked up a set of Molnar 6.700 BBC rods for my next 470 project. These rods are very lightweight at only 740 grams. I have SCAT I beam rods in my 470 right now and they are light but not that light.
Re: Molnar rods [Re: AndyF] #2171109
10/09/16 09:14 PM
10/09/16 09:14 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
got a set of gm pin 6" Molnars in my W8 mill. Definitely smaller in stature than the Eagles I had in the other engine.
Re: Molnar rods [Re: J_BODY] #2171153
10/09/16 10:18 PM
10/09/16 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Andy, you are going to like them, I have the 6.535 rod in my 512, and they checked out spot on. up
Re: Molnar rods [Re: dartman366] #2171162
10/09/16 10:26 PM
10/09/16 10:26 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I used the 7.1" rod in my 505 and love them.
I posted the weights when I built the motor and it was amazing how light my internals were!
https://board.moparts.org/ubbthreads/ubbt...440-cranks.html
Edit, not as light as I thought, but still only 1490 grams for rod and Mahle piston.
Re: Molnar rods [Re: GY3] #2171294
10/10/16 02:00 AM
10/10/16 02:00 AM
birdtracker Offline
birdtracker  Offline
What do you think the horsepower limit is on those? Birdtracker
Re: Molnar rods [Re: AndyF] #2171325
10/10/16 05:02 AM
10/10/16 05:02 AM
P
Porter67 Offline
Porter67  Offline
P
Are they pretty close to the K1-s?
I cant find me balance sheet or it should show.
Re: Molnar rods [Re: birdtracker] #2171337
10/10/16 07:30 AM
10/10/16 07:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mines never been on the dyno but runs 9.0@148 3350lbs. 7.100" Molnar with 2.200 pin". Bob weight with a little careful ring pack choice was less than with my BME aluminum rods.
Doug
Re: Molnar rods [Re: birdtracker] #2171364
10/10/16 10:26 AM
10/10/16 10:26 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If you ask that question of Tom Molnar (who is a great guy), he will tell you horsepower has nothing to do with it. It is a function of piston/pin/ring weight and RPM. Give him the weights and he can tell you the RPM you should not exceed with the rod.
Bill
Re: Molnar rods [Re: 340Cuda] #2171450
10/10/16 01:29 PM
10/10/16 01:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bill
Exactly. I told Tom my piston/ring/pin weight along with no power adder. Gave him a self imposed 7500 rpm limit. He said that they were more than enough.
Doug
Re: Molnar rods [Re: dvw] #2173790
10/13/16 05:27 PM
10/13/16 05:27 PM
dogdays Offline
dogdays  Offline
That weight total is making me laugh.
The stock piston/rod/rings/pin assembly from my '86 318 weighed more than that! Something like 1540 grams.
Shoot, the late LA motor rod at 758 grams is heavier than AndyF's bigblock rod!
R.
Re: Molnar rods [Re: AndyF] #2173928
10/13/16 07:19 PM
10/13/16 07:19 PM
AndyF Offline OP
AndyF  Offline OP
Wait until you see the pistons for this engine. JE is designing a Mopar big block piston based off the LS design. The sides are moved in so the pin is shorter than normal. Should be really lightweight.
Re: Molnar rods [Re: AndyF] #2173930
10/13/16 07:21 PM
10/13/16 07:21 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
sheeeeyit.
is it 1.32CH? so it could be used in a 451?
Re: Molnar rods [Re: dogdays] #2173955
10/13/16 07:48 PM
10/13/16 07:48 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
R.
It looks like my numbers (in the other thread) translated to over 6 lbs. of savings in the rotating assembly vs. the factory LY rods and cast pistons.
'63 Dodge 330
11.19 @ 121 mph
Re: Molnar rods [Re: AndyF] #2173956
10/13/16 07:49 PM
10/13/16 07:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm curious to see rod/piston total!
'63 Dodge 330
11.19 @ 121 mph
Re: Molnar rods [Re: GY3] #2174003
10/13/16 08:43 PM
10/13/16 08:43 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have Molnar rods and crank in my engine, along with Ross pistons. I was concerned that the crank was so light, that I would have to add mallory to the crank to balance it (because of the piston weight). The rods were light enough that I actually had to remove weight from the crank to balance it.
Very nice parts for the price.
Brian
Re: Molnar rods [Re: '72CudaRacer] #2174062
10/13/16 09:53 PM
10/13/16 09:53 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here with Icon pistons.
Re: Molnar rods [Re: dartman366] #2174075
10/13/16 10:10 PM
10/13/16 10:10 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My Mahle pistons:
'63 Dodge 330
11.19 @ 121 mph
Re: Molnar rods [Re: dartman366] #2174397
10/14/16 09:55 AM
10/14/16 09:55 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
same here with molnar crank rod and icon piston combo. rods could be used right out of the box.
Re: Molnar rods [Re: krautrock] #2174436
10/14/16 11:42 AM
10/14/16 11:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
sheeeeyit.
Yes it will be, that is the rod length and piston Ch I have with my 3.9 stroke crank.
Re: Molnar rods [Re: GY3] #2174437
10/14/16 11:43 AM
10/14/16 11:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
Factory piston and pin in a big block mopar is a little over 1000 grams.
