Re: Radiator shop epoxy repair?
[Re: pinkduster]
#2171116
10/09/16 09:22 PM
10/09/16 09:22 PM
Posts: 22,728 Bitopia
jcc
Bitopia
Good question. I actually never heard of that type of repair. I have read rad manufacturers use epoxy, but it was not supposed to be a primary structural component, if I can believe what they shared. I spoke with a niche high performance epoxy manufacturer, and gave them my parameters for a solution on a radiator, <30psi pressure, <250F, and water/glycol long term exposure, constant pressure cycling. They were most concerned with the water/glycol exposure long term, seeping into the carbon fiber filament, which is not the case for a typical rad solution issue. Never got an answer that would not require testing, and that was beyond what I wanted to invest. Lets us know what you discover.
[Re: ahy]
#2171353
10/10/16 09:54 AM
10/10/16 09:54 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i repaired many motor cycle gas tanks with JB never a prob with longevity.my curent rad in my daily driver is repaired with JB,going on 15 years no leaks.SURFACE PREP.
[Re: p d'ro]
#2173053
10/12/16 05:51 PM
10/12/16 05:51 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
My stock radiator on the 67 RT is dripping a tiny bit at a seam at the top of the tank and no one in DC metro repairs radiators. Whats the world coming to.... LOL That is sad though, no joke..
[Re: Paul_Fancsali]
#2173892
10/13/16 06:46 PM
10/13/16 06:46 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
JB it with clean prep and no coolant for at least 24 hours and don't do it outside with temps below 60 Paul is correct. I have repaired radiators both ways (solder & epoxy) and both work. 1. all epoxies will chemically resist antifreeze. 2. all epoxies will be OK with roughly 300F continuous temperature. 3. Slow cure epoxies are stronger, stick better & have better chemical resistance than 5-min. epoxies. 4. all epoxies stick very well to all metals that have proper SURFACE PREPARATION as another poster mentioned... including lead. For plastic, you need a 5-min.type epoxy designed for plastic (mercaptan based pt. B)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
