Re: BELCHING FLUID?
[Re: Magnumguy]
#2171045
10/09/16 07:59 PM
10/09/16 07:59 PM
Posts: 5,830 ohio
ruderunner
ohio
These are extremely sensitive to fluid levels. Your leak is most likely the cooler on the engine cradle rusted. Any air in the system causes fluid aeration and overflow.
Find and fix the leak. Add some fluid and drive it. Top off as needed. I like to get them hot and bleed the air out, then top em off the next morning.
Angry white pureblood male
Re: BELCHING FLUID?
[Re: Magnumguy]
#2171954
10/11/16 04:25 AM
10/11/16 04:25 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
My 99 needed a pump too. The body of the pump gets rusty from being close to the exhaust manifolds and rusts out.
Be patient when refilling. Since the reservoir is a remote fill. It takes many on / off cycles allow air to bleed out from the tiny reservoir.
