Change in valve lash and performance #2169963
10/07/16 11:01 PM
10/07/16 11:01 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Lash hot should be .020,,,,,realized it was at .025 !!
I reset everything to spec.....
Any comments on what effects on performance I might notice ??
Going to the track tomorrow.
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2169972
10/07/16 11:14 PM
10/07/16 11:14 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Too many variables. Who knows it may go slower or faster but more than likely there will not be any difference.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170032
10/08/16 12:46 AM
10/08/16 12:46 AM
It depends on how consistent the car is and how close the density altitude was and is now at race time shruggy
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170080
10/08/16 02:28 AM
10/08/16 02:28 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Doug I think it's gonna be at least a half second faster grin
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170125
10/08/16 09:23 AM
10/08/16 09:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Be careful it might slow down!
68 Barracuda Formula S 340
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170127
10/08/16 09:42 AM
10/08/16 09:42 AM
KENTUCKY
KENTUCKY
Thanks guys.
The correct lash was .020 and unbeknownst to be I had it set at .025. I will see what it does at the "correct" setting for now. Didn't want any uncessary wear if the lash was too loose.
Will see if it picks up or slows down. Thanks guys.
Case of beer to Prosport if it picks up a 1/2 second. Lol. Thanks Bob. wink
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170134
10/08/16 10:23 AM
10/08/16 10:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If it slows down 1/2 second Prosport has to send you a case of beer lol.
Good luck!
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170497
10/08/16 07:17 PM
10/08/16 07:17 PM
KENTUCKY
KENTUCKY
Car picked up all around. Was running 6.42s last week similar air. 6.39 off the trailer. 6.40 second run. 60' seems a bit better. πŸ‘πŸ‘
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170499
10/08/16 07:20 PM
10/08/16 07:20 PM
Every Mopar that I have tighten the lash up on ran faster at the track work Maybe you should try another .003 to .007 tighter now work scope twocents
Re: Change in valve lash and performance [Re: Cab_Burge] #2170533
10/08/16 08:41 PM
10/08/16 08:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I still don't understand why cam grinders specify such wide lash specs. I set mine at .012 so it's nice and quiet and it doesn't beat up the rockers and valves.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Change in valve lash and performance [Re: fourgearsavoy] #2170583
10/08/16 09:56 PM
10/08/16 09:56 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Gus beer
I have seen lash go away when the engine cools down and hang the valves open when too tight. Not a lot, just enough to not allow the engine to start.
[image][/image]
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170607
10/08/16 10:41 PM
10/08/16 10:41 PM
KENTUCKY
KENTUCKY
Ran another 6.39 with bad 60' this time. (1.44 instead of 1.41). Was hoping for a 6.36-7 per my weather station. New best MPH @ 107.5 MPH. Not sure where that came from.
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170625
10/08/16 11:16 PM
10/08/16 11:16 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Well there you go,,, maybe I should put a little more time into my lash.
How do you guys go setting lash HOT ? Are you getting the temp right up, pulling plugs, covers, finding TDC firing and then starting the process ?
I have always followed the Mopar chart, tdc set 1in 8out rotate 90deg ect.
Buy the time you do all this it is half cold ???????
1971 Barracuda
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170666
10/08/16 11:54 PM
10/08/16 11:54 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
set .006 tighter when dead cold with alum heads on iron block , have checked this when hot and it seems to be right on.
Re: Change in valve lash and performance [Re: old_racer] #2170667
10/08/16 11:58 PM
10/08/16 11:58 PM
gregsdart Offline
gregsdart  Offline
iagree
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170669
10/09/16 12:00 AM
10/09/16 12:00 AM
Ohio
lockjaw-express Offline
Ohio
Greg All,
what would you set cold at with Aluminum block and Aluminum heads with a roller cam?
Mark
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170671
10/09/16 12:05 AM
10/09/16 12:05 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Thanks Greg and old_racer .
1971 Barracuda
Re: Change in valve lash and performance [Re: lockjaw-express] #2170677
10/09/16 12:14 AM
10/09/16 12:14 AM
Washington
madscientist Offline
Washington
Originally Posted By lockjaw-express
Greg All,
Mark
Set it .010-.012 cold and check it hot. If it's still loose, tighten the cold lash to make up the difference.
I've set some all aluminum stuff as tight as .004 cold.
Re: Change in valve lash and performance [Re: 69CHARGERMD] #2170678
10/09/16 12:14 AM
10/09/16 12:14 AM
KENTUCKY
KENTUCKY
Mine is supposed to be .020 Hot,,,,,but did all my adjustments with it Cold.
I am now at .016 COLD
Sounds like I can tighten it up a bit to .014 cold according to old racer and Greg. πŸ‘πŸ‘πŸΊπŸ‘ŠπŸ»
Will keep you guys posted if the car picks up more.
Re: Change in valve lash and performance [Re: lockjaw-express] #2170680
10/09/16 12:17 AM
10/09/16 12:17 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
Mine grows .017 edelbrock hemi heads and world block so if lash Is .024 I set .007...some people here set at zero lash as it will get to .017 hot...be carful as to always warm up before you rev.
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
