Proportioning Valve - Rebuildable?
#2169775
10/07/16 06:50 PM
10/07/16 06:50 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
I pulled this proportioning valve and all of the required disc stuff (spindles, UCAs, caliper adapters, etc..)out of a junked A body about 10 years ago. Gonna need it for my '71 Dart when I do the swap from factory 10" drums to disc. Do these get gummed up internally over time? Any reason to break it open and see what's in there? Rebuildable? Or just bolt it in and go? Are rebuild kits available?
Re: Proportioning Valve - Rebuildable?
[Re: jlatessa]
#2170502
10/08/16 07:23 PM
10/08/16 07:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I'm not sure that is a proportioning valve, It is one.
[Re: jlatessa]
#2170600
10/08/16 10:23 PM
10/08/16 10:23 PM
Posts: 32 Virginia, USA
sah62
Virginia, USA
I'm not sure that is a proportioning valve, just a distribution block with a pressure imbalance switch for your "brake" light.
I took mine apart and cleaned everything, got some new O-rings and all is good.
Joe I hope the o-rings you purchased are made from EPDM rubber. The o-rings found at your local auto parts stores are typically made from a compound like Viton or Nitrile (Buna-N) rubber that isn't compatible with brake fluid. They will deteriorate rapidly.
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
2006 Dodge Charger SRT8
1995 Chevrolet Impala SS
[Re: 5carguy]
#2170903
10/09/16 02:01 PM
10/09/16 02:01 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Great information,I Thank You too. Ditto
I have mechanical Aptitude. I can screw up anything.
