Proportioning Valve - Rebuildable? #2169775
10/07/16 06:50 PM
10/07/16 06:50 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
I pulled this proportioning valve and all of the required disc stuff (spindles, UCAs, caliper adapters, etc..)out of a junked A body about 10 years ago. Gonna need it for my '71 Dart when I do the swap from factory 10" drums to disc.
Do these get gummed up internally over time? Any reason to break it open and see what's in there? Rebuildable? Or just bolt it in and go?
Are rebuild kits available?
shruggy
Re: Proportioning Valve - Rebuildable? [Re: vdriver] #2169952
10/07/16 10:52 PM
10/07/16 10:52 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Try here
https://www.musclecarresearch.com/1970-76-mopar-combo-valve-autopsy
I just purchased parts to rebuild mine, but have not done it yet.
Re: Proportioning Valve - Rebuildable? [Re: vdriver] #2169960
10/07/16 10:59 PM
10/07/16 10:59 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
There was a thread on here years ago in the Resto section that was pretty detailed with pictures. I don't have a link though.
Re: Proportioning Valve - Rebuildable? [Re: DUSTER_340] #2170029
10/08/16 12:43 AM
10/08/16 12:43 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Originally Posted By DUSTER_340
Try here
Thanks! bow Just what I needed. up
Re: Proportioning Valve - Rebuildable? [Re: vdriver] #2170448
10/08/16 06:32 PM
10/08/16 06:32 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I'm not sure that is a proportioning valve, just a distribution block with a pressure imbalance switch for your "brake" light.
I took mine apart and cleaned everything, got some new O-rings and all is good.
Joe
Re: Proportioning Valve - Rebuildable? [Re: jlatessa] #2170502
10/08/16 07:23 PM
10/08/16 07:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It is one.
Don't be the exception.
Re: Proportioning Valve - Rebuildable? [Re: vdriver] #2170518
10/08/16 07:56 PM
10/08/16 07:56 PM
New York
rarefish Online content
rarefish  Online Content
New York
The section on the right in the picture is the proportioning valve. The section on the left is the pressure switch.
Re: Proportioning Valve - Rebuildable? [Re: DUSTER_340] #2170521
10/08/16 08:00 PM
10/08/16 08:00 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Try here
Great information,I Thank You too.
Re: Proportioning Valve - Rebuildable? [Re: jlatessa] #2170600
10/08/16 10:23 PM
10/08/16 10:23 PM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
Joe
I hope the o-rings you purchased are made from EPDM rubber. The o-rings found at your local auto parts stores are typically made from a compound like Viton or Nitrile (Buna-N) rubber that isn't compatible with brake fluid. They will deteriorate rapidly.
Scott Hollenbeck Administrator, Mustang 428 Cobra Jet Registry Owner, Muscle Car Research LLC 1970 Ford Mustang Mach 1 2006 Dodge Charger SRT8 1995 Chevrolet Impala SS
Re: Proportioning Valve - Rebuildable? [Re: vdriver] #2170797
10/09/16 10:50 AM
10/09/16 10:50 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I stand corrected, I see the hex head on the end now.
I did use a rebuild kit specific for my set-up with the proper
parts.
Thanks, Joe
Re: Proportioning Valve - Rebuildable? [Re: 5carguy] #2170903
10/09/16 02:01 PM
10/09/16 02:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Ditto up
I have mechanical Aptitude.
I can screw up anything.
