Carb . #2170413
10/08/16 05:35 PM
10/08/16 05:35 PM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
So I finished my 318 for my 87 D150. It's a 90 318 with 714 swirl port heads with stock valves and a 5 angle valve job. Hughes whiplash 318 hydraulic roller cam,comp 901 springs,locks and retainers. Eddy performer intake on top with headman long tubes. Msd billet distributor with a 6a box,8.5 mm wires, summit 2800-3200 converter,3.55 sure grip rear. I have two carbs that need rebuilt. One is an Edelbrock 1405 and the other is a Holley street avenger 770. Which one will be the best fit on this mill?
Re: Carb . [Re: Eggman] #2170426
10/08/16 05:52 PM
10/08/16 05:52 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Holley gets my vote.
Re: Carb . [Re: Eggman] #2170463
10/08/16 06:48 PM
10/08/16 06:48 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I have used both brands and both have worked well.
I word start with the Edelbrock.
Re: Carb . [Re: Eggman] #2170505
10/08/16 07:28 PM
10/08/16 07:28 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Good overall carb is the 9636 Carter. Performance replacement for the 340/383
Abe Lincoln
Re: Carb . [Re: Eggman] #2170584
10/08/16 09:57 PM
10/08/16 09:57 PM
I'd definitely start with the 1405 first (get a strip kit).
